20 Most Recent Samsung ES28 Digital Camera Questions & Answers
Go into the menu settings, the flash can be set to , off , automatic, and some cameras manual
Samsung ES28... | Answered on Jul 10, 2015
1. Press down + shutter + power (firmware version is displayed) 2. Press menu - 3 seconds 3. Appear Ptp Adj Enabled 4. Press the left
Samsung ES28... | Answered on Mar 04, 2015
Hi, you may try to recover your photos from you camera.
1. connect your camera's memory card to computer using card slot on computer or a card reader.
2. downloand an useful photo recovery tool, here I recommend you to use asoftech photo recovery program http://www.asoftech.com/apr/
3. launch it, select the SD card in left list and click "Start" to start the automatic scanning process.
4. and then choose the photos you want to recover from the list of all recoverable photos and click "Recover".
Samsung ES28... | Answered on Jan 18, 2014
Did you install a SD memory card? because the internal memory is only 9Mb, and that is only enough for 1 picture in super fine mode and 2 or three pictures in normal mode. (12 M)
That will increase a factor 100 when you put a 1 Gbyte memory card in. But you also can put in SCHC in this camera. even 8 Gbyte must be very cheap now.
Samsung ES28... | Answered on Oct 28, 2013
The best free all-around photo-management/editing program is Picasa ( http://picasa.google.com ).
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Picasa or any other photo management program.
Samsung ES28... | Answered on Aug 23, 2013
The best all-around free photo management/editing program is Picasa ( http://picasa.google.com ).
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Samsung ES28... | Answered on Aug 22, 2013
Try the steps below to solve your camera issue. It should work.
Troubleshoot Camera Issues
Regards,
Sean
Samsung ES28... | Answered on Jun 09, 2013
The link below should be helpful in solving your camera issue. Try it.
Troubleshooting Camera Issues
Regards,
Sean
iPiccy is a freeware photo editing software.
You can download it from this WEB site.
http://ipiccy.com/
Samsung ES28... | Answered on May 05, 2013
YES YOU SURELY NEED THE DRIVERS. YOU CAN DOWNLOAD THEM FROM THE SAMSUNG SITE FROM THE SUPPORT SECTION.
REGARDS.
PLZ. DON'T FORGET TO RATE
Samsung ES28... | Answered on Apr 29, 2013
Samsung ES28 Digital Camera Logo
47 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
ES Samsung
  • ES Samsung
Most Popular Question
free software download
  • Cameras
