20 Most Recent Panasonic DVD-A115 Questions & Answers
open all screw, then open case
Panasonic... | Answered on Jan 17, 2011
I think you just got a bad DVD. Might be scratched, might be the wrong region, or it just might be incompatible with your player. I would tell them it won't play give me another one.
Panasonic... | Answered on Mar 03, 2010
Its always a good idea to open it up and look for accumulated dust on the lens. make sure to note where each screw goes, and such. If you see dust on the lense you can brush it off with a soft brush, and give it a damp wipe. If that didn't do anything then the lens mechanism could use a cleaning and oiling, but dont go any further if you're not confident that you know what you're doing, and don't take things apart to a degree where you're not positive that you'll remember where everything goes. I had a "no disc" error recently that was fixed by taking the lens mechanism apart cleaning and oiling it, and putting it back together. It could also be a problem with the motor. Get a repair estimate at a local shop. good luck
Panasonic... | Answered on Mar 16, 2006
Hi Amit Sharma, try replacing the two fuses that don't work
Replace them with fuses OF THE SAME VALUE, if you put more amperage, you run the risk of damaging your Panasonic Plasma TV TH42PZ700U
If you do not respond, look for a specialized technical service
Greetings Franco Dosil
Hola Amit Sharma, pruebe reemplazar los dos fusibles que no funcionan
Reemplacelos por fusibles DEL MISMO VALOR, si pone de mayor amperaje, corre el riesgo d3e perjudicar mas su TV Panasonic Plasma TH42PZ700U
Si no responde, Busque un servicio tecnico especializado
Saludos Franco Dosil
Panasonic... | Answered on Oct 13, 2019
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Panasonic... | Answered on Oct 09, 2019
Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model ...
www.amazon.co.uk > ... > TVs
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
for LED TV VIERA TX-48CX400B - Panasonic
www.panasonic.com/uk/.../viera-televisions/.../tx-48cx400b.ht...
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ‎ps4
Panasonic VIERA TX48CX400B ' 48 inch 4K Ultra HD 3D ...
Panasonic... | Answered on Oct 05, 2019
The question is ambiguous from the standpoint of signal strength or television settings. If the signal strength drops the television wont do anything till it drops below a point that it pixelates. Then you will see big squares with blotches of color and the picture appears jerky. If that is not present, it is a good thing. The television settings are a matter of personal taste.
Panasonic... | Answered on Oct 04, 2019
Hi Mohammad Hooshmand, indicates model of the Panasonic DVD you are commenting on, in order to find the best possible solution
I wait your answer
Hola Mohammad hooshmand, indica modelo del DVD Panasonic del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Panasonic... | Answered on Sep 15, 2019
Plasma TVs do run hotter than LED TVs. I suggest placing your TV into power saving mode which should reduce the heat.
Panasonic DVD-A115 Logo
5 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
panasonic dvd 115 dvd player after
  • Televison & Video
