20 Most Recent Apple iPad with Wi-Fi + 3G (Choice of 16GB, 32GB, 64GB) Tablet PC Questions & Answers
For the iPad first generation (A1219) to update is only possible with connecting the device to iTunes on a computer.
- this model supports only iOS 5
- no iOS 6/7/8 possible
update-ios-6-0-1-ipad-1-qrl052hdp2kg0kvuqxssgusw-4-0.jpg update-ios-6-0-1-ipad-1-qrl052hdp2kg0kvuqxssgusw-4-2.jpg update-ios-6-0-1-ipad-1-qrl052hdp2kg0kvuqxssgusw-4-14.jpg
Apple iPad with... | Answered on Dec 28, 2014
The mute switch is on the right side of the iPad. Check your switch settings first:
Tap Settings > General.
Under "Use Side Switch to:", select Lock Rotation or Mute.
Settings > General
Make sure you're using it to mute, and then slide the switch to toggle mute on and off. Also use the volume rocker in case you have the volume set too low.
Apple iPad with... | Answered on Nov 15, 2011
you will need a itunes account and then go to the app store. search for skype and install. it will prompt you to create a skype account if you do not already have one.
Apple iPad with... | Answered on Apr 26, 2011
Apple iPad doesn't support SWF files, you have to use special SWF to iPad Converter to play swf videos with ipad, plus, you need a special swf player, like this one
http://swfplayer.info/
Apple iPad... | Answered 5 hours ago
Try to restart the iPad :
turn it off, wait 10 for seconds, then turn it back on.
Apple iPad... | Answered on Oct 06, 2019
Hello, sorry to hear about your problems. You haven't really described the problem with any details so I will give you the best support I can with what information your provided. There could numerous problems.
1) Slotomania is down for maintenance of is experiencing technical difficulties. This is common for apps and if it is the case all you can do is wait for their support staff to fix the issue.
2) You have said "Can't Connect" so I assume you can't connect to the app server once you start the app. If a login is required double check your login details. Again, they may be having trouble on their end.
3) Give your tablet a reboot. Just simply power it off and back on. This may resolve the issue.
4) Uninstall and reinstall the app. It is possible some app system files are corrupted , even if it worked before. You would be surprised how many times just reinstalling something actually will fix the issue at hand.
Please let me know if you questions. Clarification on your problem would help in resolving it faster.
Apple iPad... | Answered on Sep 15, 2019
In fact, there are different ways to reset iPad password. You can follow below method to have a try.
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
For more methods, check: How to Unlock iPad?
Apple iPad... | Answered on Jul 23, 2019
It's usual for us to forget the passcode, however, there are several ways to reset the iPad password. Just follow one of them shown below.
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
Try below steps to unlock your iPad Air.
Apple iPad... | Answered on Jul 18, 2019
If you need to export videos from iPad to computer, there are multiple methods to complete this task. Just follow one of them.
You PC Windows Explorer is also a good free method to dispose how to transfer videos from iPad to PC without iTunes. This only needs a proper USC cable and several clicks. Follow me to check out the detailed steps.
1. Using a suitable USB cable to connect iPad to PC and then click on "Trust" button on your iPad to trust your computer.
2. Launch Windows Explorer on your PC and your iPad icon will display in the interface. Tap on the iPad icon and then choose "Internal Storage > DCIM" to click on. Thus, your iPad videos and photos will show in the folder. At last, you can copy and paste the iPad videos to a PC folder to save them.
This way to cope with how to transfer videos from iPad to PC without iTunes is quite easy. You can have a try with this simple solution to realize your goal.
transfer-videos-from-ipad-to-pc-without-itunes-but-windows-explorer-6-2ka233npl0212ndjbhnpio3z-3-0.jpg
For more methods, check: How to Transfer video from iPad to PC with or without iTunes
Of course, there are different ways to update iPad. You can follow below steps to do that.
If a message says that an update is available, you could then click "Install Now" button to start to update your iPhone iOS software. Also, you could manually check whether there is an iPhone iOS update or not on your iPhone. The below steps would show you how to update iPhone software wirelessly:
  1. Before you update iPhone software via WiFi connection, you need to make sure your iPhone has enough storage and battery to support the iPhone update.
  2. Connect your iPhone to a WiFi network.
  3. Tap "Settings > General > Software Update" successively.
  4. Tap "Download and Install" option when your iPhone has detects an update available. If a message asks to temporarily remove apps because iOS needs more space for the update, tap Continue or Cancel. Later, iOS will reinstall apps that it removed.
  5. Then iPhone would start to download and install iOS update immediately. You only need to wait for the update complete.
For more methods, check: How to Update iPad
There are a number of ways to unlock iPad. You can resort to iTunes or iCloud "Find my iPhone" feature. Just follow below steps to do that.
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
There are different ways to upgrade iPad. You can follow below steps to update your iPad with ease.
If this method won't work, check: How to Update iPhone
In your case, you can still try some methods to fix it. Just follow below steps.
iPad Air
iPad mini/iPad pro
As a matter of fact, there are a few different ways to unlock your iPad. And using iTunes will be easier. Just follow below steps.
How to unlock iPad without password using iTunes
You have to manage your iTunes account in iTunes. Follow these instructions to change account information.
You can change your Apple ID name, password, or billing information at any time.
  1. Choose Store > View My Apple ID, and sign in.
  2. Click Edit.
  3. Make your changes, and click Done.
Your changes take effect immediately.
If you also use your Apple ID in other apps, you don't need to update your information in those apps. The changes you make in iTunes apply to all apps in which you use your Apple ID.
If you have an AOL account, changes you make in iTunes don't affect your AOL account on the AOL service. For example, if you change your password in iTunes, the password you use to log in to the AOL service doesn't change.
Apple iPad... | Answered on Jul 17, 2019
There are different reasons for this issue. However, there is a great way to solve it. You can resort to this iPhone transfer software - Leawo iTransfer to sync iPad with your iPhone. Just follow below steps.
1. Run Leawo iTransfer after installing it on your PC, then connect iPhone and iPad to computer with the USB cables. The software will automatically detect the libraries of your iPhone and iPad, show the libraries of your iDevices in the left sidebar. Choose one library and the contents will be displayed in the right part of the window.
2. If you want to transfer all the files in the library from iPhone to iPad, you only need to click the transfer button at the right bottom of the window. If you only want to transfer certain files, you are able to hold "Ctrl" key and choose files, then right-click the selected files and choose "Transfer to > iPad".
3. After choosing files, you will see a pop-up dialog. Click "Transfer to List: iPad" in the dialog and then click "Transfer Now" at the right bottom of the dialog to start syncing iPhone to iPad. You will see "Save to Folder" option below "Transfer to List" option, you are allowed to transfer files from iPhone to computer by checking this option.
4. The software will start syncing iPhone to iPad after you click the "Transfer Now" button. The progress bar in the dialog will show the percentage of the process, and when the process is done, you will find the files in your iPad. You are able to check them in your iPad, or in the iPad library within the software.
For more details, check: How to Sync iPhone to iPad
Apple iPad... | Answered on Jul 15, 2019
You can try the default password or just remove the password. Follow below steps to do that.
Generally, the default passcode can be 1234 or 123456, and the digits rely on the blank number.
If this won't work, try below method.
When you find "iPad asking for passcode I never set", it is sensible for you to remove iPad passcode by restoring iPad with iTunes. The precondition is that you have backed up your iPad to iTunes before you forgot the passcode. Now let's begin to see how to get this work done.
1. Run the latest version of iTunes on your computer and then make sure that you do not connect your iPad with your computer.
2. For iPad with Face ID, you need to press and hold the top button or the volume button till you see the slider of power off shows up on the screen. Drag the slider from left to right to turn off your iPad. After that, plug your iPad into computer while holding the top button. You need to hold it until the recovery-mode screen appears.
For iPad with home button, you need to press and hold the slide or top button till you see the power off slider interface. Drag the slider from left to right to turn off your iPad. Afterwards, you need to insert your iPad into computer with proper USB cable while holding the home button. You need to hold the button until the recovery-mode screen displays.
3. In the interface of iTunes, you will see a dialogue for you to restore or update, you need to choose the option of "Restore" in the panel. Thus, iTunes will download program for your iPad. You need to wait for over 15 minutes until your iPad exit the recovery mode. Thus, you need to repeat steps 2-4.
4. Wait for the end of the procedure to set up and use your iPad without a passcode.
The process to remove iPad passcode via restoring iPad with iTunes is not so hard for you at all. You can give it a go to help you to pass through the passcode inquiry simply.
For more details, check: Fixed: iPad Asking for Passcode I Never Set
Apple iPad with Wi-Fi + 3G (Choice of 16GB, 32GB, 64GB) Tablet PC Logo
9 questions posted
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
iPad Apple
  • iPad Apple
Most Popular Question
howi install skype in ipad 2 16gb
  • Tablets & eReaders
