20 Most Recent Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator Questions & Answers
Good Afternoon Friend,
I understand you want to know what the freezer temperature should be set on for your Frigidaire refrigerator, model# FGHB2844L. Per the manual, the suggested temperatures should be 37 degrees F for the refrigerator and 0 degrees F for the freezer. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 01, 2014
Good Morning Friend,
I understand the ice maker was jammed on your Frigidaire refrigerator, model# FGHB2844L. I also see that when you pulled the tray out, there was a 3 inch plastic piece with a piece of styrofoam on it. Now there is a white cord hanging inside the ice maker. I suggest contacting your local authorized technician for further assistance. They will be able to determine what exactly is needed to repair your ice maker. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jun 30, 2014
Units will vary give or take a few degrees from the control panel display. Keep in mind once you change the temperature it will take up to 10-12 hours to stabilize and reach that temperature. If the unit is not cool, even at the bottom of the refrigeration portion (where the coolest air will be found) then contact a professional to diagnose the control pane and board.
Frigidaire... | Answered on Jun 07, 2014
When you purchased the unit it came with a complete instruction manual and guide. Thumb through your book and locate the answer there.
Frigidaire... | Answered on May 10, 2014
Hello Marc Donmoyer - Could the error code be SY CE? If so, then the refrigerator has detected a communication error at power up. Contact a professional to move forward accurately to check the wiring between main control board and user interface. Depending on the diagnoses, either or will need replacing.
Frigidaire... | Answered on Apr 21, 2014
The filter under the sink should have nothing to do with the water supply to the icemaker. The "repairman" probably cut off the icemaker water supply by "bypassing" the filter.
Frigidaire... | Answered on Jan 08, 2014
Good Afternoon Johnny, thank you for your inquiry! Error code SY CE, commonly refers to a communication error at power up. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn on the unit. If resetting the power does not correct the issue, than the unit could possibly be experiencing a communication problem with the control board or a faulty user interface board. In this regard, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered.
Frigidaire... | Answered on Jul 29, 2013
Hello - Often when the refrigerator is inoperable and has no LED lights, it is because it could be something as simple as a damaged cord or an issue more complicated that requires the help of a professional. Check that the household circuit breaker has not been tripped or that any fuses are blown. Also, try reprogramming the refrigerator by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the fuses are working fine, however issue persists, then the refrigerator may be experiencing some form of a sealed system issue or a faulty electronic control board. At this point, I would personally recommend contacting a certified technician to accurately diagnose the unit to determine the root cause to reduce the risk of unnecessary parts.
Frigidaire... | Answered on Mar 22, 2013
Hello Todd Line - Often when the refrigerator is inoperable and has no LED lights, it is because it could be something as simple as a damaged cord or an issue more complicated that requires the help of a professional. Check that the household circuit breaker has not been tripped or that any fuses are blown. Also, try reprogramming the refrigerator by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the fuses are working fine, however issue persists, then the refrigerator may be experiencing some form of a sealed system issue or a faulty electronic control board. At this point, I would personally recommend contacting a certified technician to accurately diagnose the unit to determine the root cause to reduce the risk of unnecessary parts.
Hello Rocco Berardi - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Frigidaire... | Answered on Jan 28, 2013
Hello jcwilson2929 - If your ice maker has stopped producing ice completely, you can check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Frigidaire... | Answered on Jan 22, 2013
Hello jgamewell - Sounds like the dispenser could possibly have a broken or frozen door dispenser sealed. Contact a professional to move forward accurately to properly repair/reinstall part.
Frigidaire... | Answered on Jan 08, 2013
Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator Logo
57 questions posted
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
repairman made service call checked out
  • Refrigerators
