20 Most Recent Kodak EasyShare CX7530 Digital Camera Questions & Answers
Go to Kodak.com you can download a manual from there . if you have a computer download the pictures to the hard drive . do this with a card reader . or connect with USB cable . The photo can be added to the email as a attachment.
Kodak EasyShare... | Answered on Nov 29, 2014
The CX7530 works with MMC and SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards.
Kodak EasyShare... | Answered on Apr 16, 2014
Sane problem with C713, the view screen is dark and gives focus warning, then the pics come out with a pink tint. I believe it is the sensor or shutter problem. Can't get any solutions either.
Kodak EasyShare... | Answered on Feb 18, 2014
The CX7530 works with MMC and SD cards, 2GB or smaller. It won't work with larger memory cards, which is what you're trying to do.
Kodak EasyShare... | Answered on Jan 30, 2014
Not with this camera. The CX7530 works with MMC and SD cards, which max out at 2GB. It will not work with larger memory cards.
?!? Don't strike the camera...
Kodak EasyShare... | Answered on Jan 06, 2014
Go in settings, change the Date and Time setting.
Kodak EasyShare... | Answered on Oct 25, 2013
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Kodak EasyShare... | Answered on Feb 17, 2013
Turn off the "Date Stamp" setting in the settings menu. See this page of the user guide.
Kodak EasyShare... | Answered on Jan 14, 2013
The CX7530 works with SD cards. It will not work with higher-capacity SDHC cards. You need to use SD cards, 2GB and smaller.
Kodak EasyShare... | Answered on Nov 05, 2012
You may view the user guide here and view/download the extended user guide here.
Kodak EasyShare... | Answered on Oct 28, 2012
If you want your camera to automatically deface all your photos by scrawling a string of numbers across them, press the MENU button, use up/down-arrow to select SETUP (three horizontal slider), press the OK button, use up/down-arrow to select "Date Stamp", select the desired setting, and press OK.
Kodak EasyShare... | Answered on Oct 27, 2012
Most of the digital cameras come with a software to do that. Firs and the most important thing is to make sure the drivers for you camera are loaded and your camera is recognized by the computer. The rest should be easy, just launch the photo manager program that came with your camera and the rest is easy as following the instructions. If you did not get a software package from the manufacturer you can down load it from the internet.
Check Out:-
Kodak EasyShare... | Answered on Sep 12, 2012
see the video instructional and proceed with common sense and logically. God bless you
Kodak EasyShare... | Answered on Aug 03, 2012
Kodak EasyShare CX7530 Digital Camera Logo
137 questions posted
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
camera wont format
  • Cameras
