20 Most Recent Kodak EasyShare One Digital Camera Questions & Answers
If the pictures were on a memory card and you haven't done anything with the card since you deleted the pictures, you have a chance to recover at least some of them. Do a Google search for "data recovery software" and select a program appropriate for your computer and operating system. Put the memory card into a card reader connected to your computer and run the program.
Kodak EasyShare... | Answered on Dec 21, 2018
It's time for a new one, uneconomical to repair.
Kodak EasyShare... | Answered on Jan 11, 2018
Your display screen is damaged. Just get it replaced at nearby camera technician. It should be all right.
Kodak EasyShare... | Answered on Oct 01, 2017
This is very upsetting for you, but unfortunately Fixya has no connection with Kodak. You may be able to get assistance directly from Kodak.
Kodak EasyShare... | Answered on Aug 01, 2017
There Is no one thing you can do to fix this camera, you have two choices, send it in to Kodak for repair or replace it.
Kodak EasyShare... | Answered on Jul 22, 2017
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Kodak EasyShare... | Answered on Jan 09, 2017
Are you using Lithium batteries?
ALL Kodak cameras have huge problems with alkaline batteries.
Hope this helps.
Kodak EasyShare... | Answered on Mar 29, 2015
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Kodak EasyShare... | Answered on Aug 23, 2014
These cameras have an internal store and also can use a card. So, when you add a card, it is writing to that store and only shows you the pictures stored there unless you change the device settings or remove the card.
If so, the images you have on the EasyShare One internal store may be originals
Another possibility is that you did a BragBook synch to EasyShare and you might be able to see these images in your 'Favorites' view. The 'Camera Favorites' or BragBook pictures are a smaller version of original images, to allow you to carry more pictures with you to share, but these pictures may be a lower resolution version of the images you took. They would be sufficient for printing 4x6 pictures, but not enlargements.
Change to Favorites mode to see if they show up that way.
DigiChick.
Kodak EasyShare... | Answered on Apr 18, 2014
Are you sure? Where are you seeing the date? As far as I'm aware, the M530 can't stamp the date on the pics. It can show the date when reviewing pics, and just about any photo printing program can print the date along with the photo, but the camera won't hide anything behind the date.
Kodak EasyShare... | Answered on Dec 18, 2013
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
hi there,
have you tried CARD RECOVERY. down load from google. it will retrive all photos ever taken on that memory card...
good luck
Kodak EasyShare... | Answered on Nov 27, 2013
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card.
Kodak EasyShare... | Answered on Oct 19, 2013
Kodak EasyShare One Digital Camera Logo
487 questions posted
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
will not let me see any photos
  • Cameras
