20 Most Recent ASUS Eee Pad Transformer TF101A1 Tablet Computer Questions & Answers
batteries do not last forever get it replaced by a computer shop
ASUS Eee Pad... | Answered on Jan 05, 2018
go to xda developers .com and ask question there.
ASUS Eee Pad... | Answered on Dec 13, 2017
Hi
Download from the link below for free.
http://www.mozilla.org/en-US/firefox/new/
ASUS Eee Pad... | Answered on Aug 05, 2016
MEID number is same as IMEI number.
You can see this in Settings->About Phone
ASUS Eee Pad... | Answered on Apr 23, 2016
sorry Cynthia but that is not what we do here .
ASUS Eee Pad... | Answered on Aug 18, 2015
Hold you're power button down for about 30 seconds or more if it won't turn on leave it on charge and try 30 min later hope it works it did for me.....
ASUS Eee Pad... | Answered on Jun 30, 2015
Pamela, let it completely dry so don't turn it on until dry.Do not use dryer etc. Had similar problem on smart phone.
ASUS Eee Pad... | Answered on May 06, 2015
Just change the settings. If you are getting to the "asus.com" site then the browser is working. If you want it to open to a different site, tap on the 3 dots in the upper right portion of the page. This will open a new dialog box. Go to the settings and from there you should be able to set a new homepage to open to.
I do not know which browser you are using, but recommend google) Download the app from the Play Store https://play.google.com/store
IE (Internet Explorer) does not work on ASUS tablets as it is windows based and your tablet is running Android operating system. stick with Google or maybe Firefox browsers.
J
ASUS Eee Pad... | Answered on Apr 29, 2015
contact Asus of course we do not know it or have any here
ASUS Eee Pad... | Answered on Apr 28, 2015
look for setting /sounds and turn mute off
Were you using the right charger? Just because the plug fits doesn't necessarily mean the current is right. Normal charging voltage is about 5V, not nearly enough to cause a spark, so it doesn't sound good to me. If it's still under warranty (or even if it's not) this may need a trip to tech support
ASUS Eee Pad... | Answered on Feb 12, 2015
Sounds like a faulty display chip on the motherboard so a trip to a repairer is the only way to go, it'll cost sub £100
ASUS Eee Pad... | Answered on Feb 06, 2015
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
ASUS Eee Pad... | Answered on Dec 31, 2014
ASUS Eee Pad Transformer TF101A1 Tablet Computer Logo
222 questions posted
Top ASUS Tablets & eReaders Experts
Ekse
Terry
Alun Cox
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Tablets & eReaders
Most Popular Question
want download firefox
  • Tablets & eReaders
