20 Most Recent LG WD-80130F Questions & Answers
It could be damaged or worn bearings. It can also be a broken spider. The spider attaches to the inner drum and is part of the spindle assembly.
LG WD-80130F | Answered on Jul 12, 2019
Where do sparks come from. Motor is in back.
LG WD-80130F | Answered on Mar 12, 2017
PE= pressure error. A water level error. Check hose to pressure sensor. Is it connected? Does it have a hole in it? Otherwise replace pressure sensor.
LG Washing... | Answered 16 hours ago
WHILE IT IS LOADING WATER, TRY TO ADVANCE THE WASH PROGRAM; INSTEAD OF LARGE CAPACITY GO TO MEDIUM.
LG Washing... | Answered 3 days ago
Take top off, take control panel off, remove front panel.
LG Washing... | Answered on Jul 13, 2019
I'm sure you double checked, but I have forgotten to plug the connectors from the control back together before putting the top back on. Seems obvious but I've done it more than once. Good luck. (And make sure your house breaker isn't tripped)
LG Washing... | Answered on Jul 08, 2019
The lid has hinges on the back so it rotates back from the front. The front is held in place but two metal clips. Push a metal spatula in the seam between the top and front to release the clips. Clips are about 1/4 in from each side.
LG Washing... | Answered on Jul 04, 2019
If this is a front loader and older model check the spider arm on the back of the drum it may be corroded and putting the drum off center at low speed. I just replaced the drum to tub gasket and the spider arm which was severely corroded (name may not be correct go to the LG parts site)
LG Washing... | Answered on Jul 02, 2019
I just finish repairing my LG front loader and this sounds like the same issue. The back of the drum has a spider arm and spindle arrangement (think that the name) the spider are was corroded and broke after 10 years, this puts the drum off balance and chews up the gasket. I had to also repair the wash tub where the drum had worn into it and JB Weld worked fine. It all seem to work fine now.
LG Washing... | Answered on Jul 01, 2019
DL is indeed a door lock error. The code is generated when the CCU can't lock the door. Possible causes are door latch mechanism, connecting wiring, or the CCU. You could hear clicking from the CCU machine which indicated to me the CCU was trying to lock the door. It tries 6 times before setting the F/DL code.
?Check Door Lock/Switch Assembly for foreign objects
?Check Wire Harness connections to the Door Lock/Switch Assembly
All the best !
LG Washing... | Answered on Jun 30, 2019
could be lid switch are some else, you should call techicain to help you out
LG Washing... | Answered on Jun 24, 2019
Possibly the circuit breaker failed and cannot be reset.
LG Washing... | Answered on Jun 23, 2019
Washing Machines Logo
10 questions posted
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
lgwd80130f high spedd spin problem
  • Washing Machines
