20 Most Recent Samsung ML 1710 Laser Printer Questions & Answers
You can download the printer driver from the Samsung WEB download site, please click on this link to download :-
http://www.samsung.com/sg/support/detail/supportPrdDetail.do?menu=SP02&prd_ia_cd=06010400&prd_mdl_cd=&prd_mdl_name=ML-1710#
Samsung ML 1710... | Answered on Mar 06, 2019
pls. copy paste this link your explorer and type your model......you can get all the available samsung printer model driver.......... Enjoy.........
http://www.samsung.com/in/support/download/supportDownMain.do
Samsung ML 1710... | Answered on Nov 09, 2018
Not following you, you said Samsung 3710, correct
Samsung ML 1710... | Answered on Feb 09, 2018
you try clean paper sensor..maybe more dust of toner cover to the paper sensor.
Samsung ML 1710... | Answered on Sep 07, 2016
Hello, here ML 1710 DOWNLOADS SUPPORT SAMSUNG you can download the driver for any kind of OS.
Samsung ML 1710... | Answered on Jul 29, 2014
hi,your question is not compleat but papper jam is mainly complaint for you check the cartridge &fuser unit &papper pikup unit
Samsung ML 1710... | Answered on May 06, 2014
hi,your priner cartridge is checkig ,cartridge drum jam in to the papper is jam,or printer fuser unit replace
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Samsung ML 1710... | Answered on Apr 08, 2014
First, pull the tray out. Next, look for a WIDE rubber roller
right in the middle of two smaller black rollers, that's the
one you want to clean! Grab a lint-free rag (important!!),
get some alcohol. Next, dampen the rag with the alcohol and
start wiping across the wide roller so that when you rub your
finger tip across it, your finger barley budges, this means
it's completely clean. Now, here's the trick, there's a
black, thin lever that hangs down on the left side under the
bottom of the printer, this detects the paper level, it's
hangs loosely and you can push it up easily with your finger.
With the tray still pulled out, push the lever up so that the
status light on the printer turns green. Now, if you're close
enough to your computer, send one page to print while keeping
that lever pushed in. What you want to do here is watch as
that WIDE roller turns over to the other side where there is
still dirt that needs to be cleaned off. You've got to be
fast and time it right so that you can turn off the printer
as the WIDE roller flips to the other side, cause once it
gets there, you've got to turn the printer off to stop it
dead in it's tracks. Getting another person to help would be
best for this task. TRUST me, once you get that whole roller
cleaned with alcohol, it works like new!! :)
Samsung ML 1710... | Answered on Feb 09, 2014
bagaimana cara menghilangkan kotor di ujung-ujung kertas setelah di print
Samsung ML 1710... | Answered on Dec 27, 2013
printer epson stylus office hasil cetak sering kotor ada tinta bercak-bercak
Samsung ML 1710 Laser Printer Logo
168 questions posted
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
ML Samsung
  • ML Samsung
Most Popular Question
lost cd install printer
  • Office Equipment & Supplies
