20 Most Recent Ricoh Aficio 1515MF All-In-One Laser Printer Questions & Answers
Red light all time when ink is finished and refilled it.
Ricoh Aficio... | Answered on Sep 11, 2019
press the orange key threee times and enter 107 and then press and hold the stop key for about five seconds.
the machine then takes you into the sysytem. select sp mode on the screen. put off the machine for a minute and put on again
Ricoh Aficio... | Answered on Jun 13, 2019
Finally figured this out!!
Go to: UserTools - System Settings - File Transfer Tab - page 3 of 3 - Auto-Specify Sender Name - <ON>
Ricoh Aficio... | Answered on Jun 26, 2018
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Ricoh Aficio... | Answered on Apr 18, 2018
First download the twain drivers from Ricoh website or if you have cd down load it from it. Then from there when you go to scan should give you selection option for it.
try to download the new driver for vista from www.ricoh.com
if done then goto start-programs-twain4-network connection tools check weather right ip is given or not
Clean MBU interface. Clean with dev. Make sure you can see gold pins. Clean male adapter on MBU board with dev. Pic : SP201 ricoh MBU clean up with dev.
Ricoh Aficio... | Answered on Mar 08, 2018
Could be one of a few things:
Most likely is the transfer roller. If it's dirty or old and not applying enough charge, it may not be pulling all the toner away from the drum. Replacing the transfer roller is easy if you can get a new one.
Are you sure you have the correct toner? The wrong toner can definitely cause copy quality problems.
If the springs that hold the press roller against the hot roller are not properly in place (or if they have started to lose tension) the toner won't be fully fused onto the paper.
I'd start with the transfer roller (black roller that sits opposite the drum on the right side door) first -- it's the most likely culprit.
Ricoh Aficio... | Answered on Nov 20, 2017
Easier said than done...you'll probably need a tech for this one.
First..to scan to folder you require a software called "scanrouter Lite" from Ricoh, which is actually kind of hard to get a hold of these days, since it's nnot supported anymore, and then the configuration is not easy , because it is proprietary...meaning only Ricoh uses it, and it is almost impossible to configure for anyone else that has not used it.
There is however Scan to email, and for this you can open a web browser, and type it's Ip address (if you have it connected via tcp/ip port), enter "admin mode"...user name= "admin", password = "password"...then enter all network settings...IP, DNS, POP,SMTP, etc. then in "address book" enter your destination settings.
This is not a configuration that is easy for a novice either, and it is also not compatible with an email server that uses authentication for outgoing mail.
I may not have helped, b ut I hope I clarified.
Ricoh Aficio... | Answered on Sep 14, 2017
820 Self-diagnostic error: CPU
Symptom:
• An unexpected exception or
interruption occurs during the self-
diagnostic test.
• An error is detected in the MBU.
Possible Cause:
• Defective controller
• Defective firmware
• Loose MBU jumper
Code 820
MBU error (The jumper is loose.)
Set the jumper (on the MBU) correctly.
The following codes are displayed:
• SC: 820
• code: 612
• detail: 40000000
Ricoh Aficio... | Answered on Aug 10, 2017
Here is the link to Ricoh's website and the 1515 drivers. Just select your PC's operating system.
Good Luck and Thank You for using Fixya.
Please return and give me feedback on my solution.
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x15_15f/x15_15fen.htm
Ricoh Aficio... | Answered on Aug 09, 2017
If you are using an LDAP server to provide the destination, you may not have the Search Conditions programmed correctly.
Ricoh Aficio... | Answered on Mar 06, 2017
You need a tech...here is the description of your "SC":
The scanner home position sensor
does not detect the scanner leaving
the home position.
Here are the possible solutions:
- Defective scanner home
position sensor
- Defective scanner drive motor
position sensor connector
connector
- Defective BICU board
Ricoh Aficio... | Answered on Aug 15, 2016
TD sensor is a electronic sensor that is short term from T-toner & D-density, so the Toner Density sensor is at is says Detects and measures how much and does have a toner in the developer unit.
Ricoh Aficio... | Answered on Apr 14, 2016
Sounds like it thinks there is a jam. Check registeration sensor flag also exit sensor and duplex sensor. Could be dust or fuser sensor out of place or the duplex guide is broken
Ricoh Aficio... | Answered on Mar 05, 2016
To clear the memory (reboot) the RICOH AFICIO you will have to send it to the factory where they will wipe the memory and restore the machine to its defaults.
Ricoh Aficio... | Answered on Feb 29, 2016
please your copier fuser thermostator is displace or over dust toner clean it and solve your problem
Ricoh Aficio... | Answered on Jan 14, 2016
The photo conductor is the round drum unit that is light sensitive. The laser in the printer writes an image of what you want to print on the drum and then the toner is applied to the drum and transferred to the paper.
Ricoh Aficio... | Answered on Aug 30, 2015
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
297 questions posted
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
error code sc 120
  • Office Equipment & Supplies
