20 Most Recent Canon Rebel XT / EOS 350D Digital Camera Questions & Answers
Canon Rebel XT /... | Answered on Jan 10, 2019
change your manual settings
Hi there! I suspect that your memory card is probably damaged. Did you try a different memory card? Postback so that we can proceed further..
Canon Rebel XT /... | Answered on Dec 01, 2018
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
When you change the zoom, chances are the camera lose focus, and you need to half-press the shutter button again to the camera autofocus.
Its normal behavior to lose focus when zooming in or out.
Canon Rebel XT /... | Answered on Sep 25, 2018
Maybe there's a problem with your camera's pop-up flash.
Contact Canon Customer Support, and see what they can do for you. Probably they will point where you can get your camera repaired.
Photography is the process of making pictures (graph) using light (photo)...
Light takes the most important role on produce nice pictures
There`re no fixed rules about photography, it`s an art so nobody have rights to say that the photo is good or bad...
During rainy day, you should prepare camera`s water-proof jacket or an umbrella to protect it against water. Some expensive cameras have been equipped with water-proof material.
Canon Rebel XT /... | Answered on Jun 22, 2018
Try using a small pencil eraser or a fiberglass brush on the battery contacts. Do this on just the battery, not the camera contacts. Do very little and try it in the camera again. If it doesn't improve, try a new battery.
Canon Rebel XT /... | Answered on Dec 30, 2017
Take it back to where you bought it and get them to replace it or fix it under the guarantee.
Canon Rebel XT /... | Answered on Nov 16, 2017
Sound like a broken ribbon cable in the lens. Needs to be replaced but get a quote as it may be cheaper to replace the lens with a secondhand one.
Canon Rebel XT /... | Answered on Sep 23, 2017
This sounds like a broken ribbon cable in the lens Take it for repair This type of repair is relatively inexpensive but get a quote as it may be cheaper to replace the lens with a secondhand one.
You have your own answer - the lens is damaged, probably beyond economic repair.
Canon Rebel XT /... | Answered on Sep 12, 2017
in manual mode, will not try to focus itself, my be the manual auto switch is faulty, or the focus related mechanism not rotating the lens, open the lens carefully check the focus motor and gear set (engine is the technical term)
Canon Rebel XT /... | Answered on Sep 10, 2017
Take it to a service centre, let them deal with it, and fix the problem that has caused this.
Canon Rebel XT /... | Answered on May 29, 2017
Canon Rebel XT / EOS 350D Digital Camera Logo
1,519 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Rebel Canon
  • Rebel Canon
Most Popular Question
error 99 in canon eos 350 d
  • Cameras
