20 Most Recent Panasonic Lumix DMC-FZ10 Digital Camera Questions & Answers
If you want to delet from your camera or your computer. On the computer, find your Photo files from your computer. Right click on the photo, it should show up blue highlighted, then right click "delete." There should also be a "delete" button your camera settings. Check your manual.
Panasonic Lumix... | Answered on Feb 13, 2015
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Panasonic Lumix... | Answered on Mar 22, 2014
I suggest trying another SD Card to see if you get the same error message. If not then it was the card.
Panasonic Lumix... | Answered on Oct 24, 2013
http://www.ifixit.com/Wiki/Panasonic_Lumix_DMC-TZ5_Troubleshooting
carefully read the link
Define a specific problem for exact solution.
Panasonic Lumix... | Answered on Oct 22, 2013
The fault of a lens error be it in the shutter, zoom or auto focus is due to failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Panasonic Lumix... | Answered on Aug 31, 2011
yes......but try manual mode and drop one fstop
Panasonic Lumix... | Answered on Apr 09, 2011
It's likely that there are settings on the camera that change the menu style - my Panasonic lets me reorganize the menus and change the way they look.
Here's the manual: http://www.fixya.com/support/p326380-panasonic_lumix_dmc_fz10_digital_camera/manual-8327
Panasonic Lumix... | Answered on Mar 07, 2011
See if the card has issues - can another device (PC , another camera). Try reformatting the card - use a pc card reader, my computer, right click on the card, pick "format".
Panasonic Lumix... | Answered on Feb 27, 2011
This camera should be able to use any SD card of 1GB or less capacity. If you have been trying to use larger capacity cards, that will be your problem (larger cards are actually SDHC, which fit the same slot but are different electrically). If the cards you have been trying are smaller than that, then there is most likely a fault.
These cameras come with a memory card that will work with them (it is very small capacity). If you have tried to use that one and it won't work, then return the camera under warranty.
Panasonic Lumix... | Answered on Dec 25, 2010
$50.00 to $100. Remember, it is only worth what someone is willing to pay for it. These are prices extracted from eBay auction sales in the last 30 days that have closed.
Panasonic Lumix... | Answered on Dec 20, 2010
Ofcourse it can be repaired. All you need to do is check the flash bulb. Most probably the bulb is fused or there might be an internal wiring problem. Get it repaired in some customer care.
Panasonic Lumix... | Answered on Aug 06, 2010
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Panasonic Lumix... | Answered on Jul 12, 2010
Without more info and suggesting something useful for you, you might want to try a new or different card in your camera. Make sure the card is the generation of card that your camera wants to use. Consult the owner's manual and online. Is this the same card that came with the camera or otherwise worked for you before the trouble? The only other thing (obviously) is that the camera itself might need servicing. Good luck.
Panasonic Lumix... | Answered on Nov 28, 2009
Check if you have activated the Electronic Viewfinder (EVF). Press the EVF/LCD button to switch to the LCD screen. If this fails to solve the problem, change the mode dial to Auto (the red camera icon) or 'P' and try again. If even this does not work, check with the nearest authorized service center.
Panasonic Lumix... | Answered on Nov 05, 2009
I suspect that water has damaged the electronics board in the camera. Unfortunately this is not a waterproof camera. Water will corrode the electronic components and eventually ruin the whole camera,
My suggestion is to claim it on insurance as they wilol repair or replace it on Home insurance. No one puts a camera in water intentionally unless its an underwater camea, so its considered an accident
Please rate our help to keep the Free service online ++++
Thank you for using FIXYA
Panasonic Lumix... | Answered on Sep 01, 2009
Panasonic Lumix DMC-FZ10 Digital Camera Logo
61 questions posted
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
lumix dmc fz10 erro
  • Cameras
