20 Most Recent Westinghouse LD-4055 40 Class LED HDTV -1080p, 1920 x 1080, 16:9, 4000 Questions & Answers
turning off loud speaker bt6500
Westinghouse... | Answered on May 21, 2014
lg tv model 21fj8rg3t8
H OUT (2) folister capasiter valu
Westinghouse... | Answered on Sep 07, 2013
I don't believe it is. Westinghouse mention nothing about it in the Manual. However, whether it is or not, it won't make a difference in the sound system you buy. If you get your cable feed from the TV's tuner you can connect the Digital Coaxial output from the TV to your new HT receiver.
Westinghouse... | Answered on Oct 31, 2012
4mm diameter by 7mm long screws avail @Lowes in special fastener section
Westinghouse... | Answered on May 28, 2012
How do you know it has no power, did you test the wall plug?
Westinghouse... | Answered on Oct 08, 2019
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Westinghouse... | Answered on Oct 06, 2019
The applicable code would be in a compatible remote control, not your TV.
Westinghouse... | Answered on Sep 19, 2019
May be a capacitor on the board going bad.
Westinghouse... | Answered on Sep 11, 2019
Hi Matt Ray, the LED driver is on the same Power Supply board
Regards Franco Dosil
Hola Matt Ray, el controlador de LEDs esta en la misma placa de Fuente de Alimentacion
Saludos Franco Dosil
Westinghouse... | Answered on Sep 10, 2019
Westinghouse is known for using 999999 as the factory password
Westinghouse... | Answered on Sep 05, 2019
Westinghouse LD-4055 40 Class LED HDTV -1080p, 1920 x 1080, 16:9, 4000 Logo
Popular Tags
11 questions posted
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
westinghouse led tv ld 4055 arc
  • Televison & Video
