20 Most Recent HP : HP6L Laserjet Printer Questions & Answers
Thank you for contacting FixYa with your printer inquiry.
This error is normally associated with a supplies error. I have extracted information on this error from the HP 6L manual.
Error Codes
Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer model
    The printer is unable to read the electronic information (elabel) on the print cartridge. This helps track page count and life of consumable.
    XX Description 00 memory error on the cartridge or 01 memory device not found
    10.00.00 Black print cartridge
    10.00.01 Cyan print cartridge
    10.00.02 Magenta print cartridge
    10.00.03 Yellow print cartridge
  1. Supplies used in newer printer models contain a memory chip. The information contained on this chip is dependent on the printer model and the supply. The error 10 indicates a problem with the printer obtaining the information from this chip. The chip may be missing or defective or contain incorrect information. There may be a problem with connection between the memory chip and DC controller. Turn the printer off/on to attempt to clear or reset the message. Remove and reinstall the supply, replace the supply.
  2. Replace the memory chip cable/connector or the DC controller.
    How did we do?
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
HP : HP6L... | Answered on Jun 13, 2014
I am not sure what printer you have here but if you are having repeat images down the page then it more than likely that you have a faulty toner cartridge. Try changing the toner cartridge first.
If that does,nt solve the problem then you have a defective fuser assembly.
HP : HP6L... | Answered on Jun 10, 2011
the laser scanner might be dirty which will cause a reduction in print quality. Is the inside of the printer clean?
HP : HP6L... | Answered on May 22, 2011
This type of printer does not use ink cartridges, and instead uses toner cartridges.
When the toner starts to get low, you will see the print fading on the page.
You can buy a replacement cartridge directly from the HP website from this link:
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=CB411A&aoid=5504&lang=en&cc=us
HP : HP6L... | Answered on Feb 26, 2011
restart printer and pc it will be ok
HP : HP6L... | Answered on Nov 14, 2009
What did HP support fail to show you, please?
HP Office... | Answered 7 hours ago
Hi, i cant match these part numbers up to anything HP. Are they possibly a compatible and not Genuine HP ink.
HP Office... | Answered Yesterday
6 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
hp laserjet 1006 dont know
  • Office Equipment & Supplies
