20 Most Recent Miele Touchtronic W1213 Front Load Washer Questions & Answers
Foam has probably got into the logic board, and a new board is probably needed. Sorry !
Miele... | Answered on Feb 02, 2018
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
Miele... | Answered on Apr 08, 2016
Hi Chantal,
In my many years repairing Miele machines - the most common problem for what you are describing is the underwire from a bra has got in between the inner and outer drum. It's tricky to get out and can be done if you are good with tools and a little technical - but it does involve opening up the machine, removing one of the heating ellements and searching / fishing it out. Another less common reason for this rubbing noise could be the metal heater element bracket that also sits between the inner & outer drum, has bent - but this is normally caused by a bra underwire. Hope this helps.
Miele... | Answered on Sep 26, 2015
Check the start up relay is clicking when you first turn it on , then check thermostat.
Miele... | Answered on Nov 15, 2014
go on line to miele spare parts and they can help you
Miele... | Answered on Jan 25, 2014
Miele Touchtronic W1213 Front Load Washer Logo
85 questions posted
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Marvin
Marvin
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Miele Washing Machines
Most Popular Question
live in venezuela need know serial spare
  • Washing Machines
