20 Most Recent Frigidaire Refrigerator White Fridge & Freezer Handle Set - 5304485330 Questions & Answers
Hello Sammy, thank you for your post!
I understand that the filter inside of your Frigidaire refrigerator pops out when you push in on the dispenser. This could be an issue with the filter. I would suggest reinstalling the filter and assuring that you can hear a connection within the housing. If the filter is not connected properly once water has pushed through it will dislodge from the housing. The housing could also be causing an issue within the connection. Is your filter a new filter? You may need to change it for the gaskets to be new. If you continue to experience issues I would recommend seeking help with a professional technician for a proper diagnosis to be completed. This will help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Frigidaire... | Answered on Mar 10, 2016
Hey Michael, thank you for your post!
Based off what you have described your Frigidaire refrigerator drain pipe is plugged up. You can clear out any clog within your drain by performing a manual defrost. In order to defrost your refrigerator you would need to disconnect power from it for at least one hour. If this does not help your issue I would suggest seeking assistance from a professional technician. I hope that this information is helpful to you. -Matt
Frigidaire... | Answered on Mar 03, 2016
call in a service technician or an accredited refrigeration repairer for a proper diagnosis and quote
could be a faulty thermostat for the fridge side
Frigidaire... | Answered on Jan 20, 2016
Hi, they can be repaired with a plastic solvent glue usually comes in tubes. Make sure the tray is dry and at room temperature before putting the glue on. It should slightly melt the plastic and fuse it together. I would put another coat of glue on once the first coat is dry.
Frigidaire... | Answered on Dec 24, 2015
located where temp dial is in fridge side
Frigidaire... | Answered on Dec 21, 2014
Turn the knob.
Frigidaire... | Answered on Dec 10, 2014
If you check the specs on the manufacturer website, it will detail an aprox yearly consumption.
Frigidaire... | Answered on Mar 25, 2014
Push the trim length wise, eg. place palms on upper trim, push down against trim and up, if forced it may crack so try it in lightly 1st. Just move it enough too tighten the door screws.
Frigidaire... | Answered on Oct 31, 2013
Look on the spec label that shows voltage, amps, model number and serial number. This is often at the rear near the mains wire or on a label inside the fridge.
Frigidaire... | Answered Yesterday
Replace the hose that’s leaking
Frigidaire... | Answered 2 days ago
Good Afternoon Gerald, thank you for your post!
I see that your Frigidaire refrigerator is only dispensing crushed ice not cubed ice. Your solenoid (which tells the dispenser crushed or cubed) might be frozen. You can defrost the solenoid by disabling power from it for at least one hour and then restoring power. If you continue to experience this issue you may need to have the solenoid replaced or the control panel and I would suggest having a professional technician out for proper repairs. Good luck with your refrigerator! -Matt
Frigidaire... | Answered on Jan 13, 2019
The bucket is probably frozen in it mount. Turn off refrigerator until it defrost enough to release it
Frigidaire... | Answered on Jan 12, 2019
This is usually caused by a clogged drain hose. Blow air thru it from the back to clear the clog. Good luck, hope this helps. Also make sure door seals are good and doors are closing properly.
Frigidaire... | Answered on Jan 02, 2019
Frigidaire Refrigerator White Fridge & Freezer Handle Set - 5304485330 Logo
17 questions posted
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
18 2 cu ft in inches
  • Refrigerators
