20 Most Recent LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Questions & Answers
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
LG Flatron... | Answered on Apr 23, 2019
That's probably a message from the monitor because it's not getting a signal from the computer. Look at the VGA cord where it plugs into the computer, or the monitor to see if you bent pins when reinserting the plug.
LG Flatron... | Answered on Feb 18, 2018
It looks like you need a new monitor
LG Flatron... | Answered on Nov 08, 2017
do you have speakers on your monitor? If yes, check the wire connecing hte sound to the speakers
LG Flatron... | Answered on Apr 10, 2015
Is it a moniter
LG Flatron... | Answered on Mar 07, 2014
Check cable
LG Flatron... | Answered on Nov 27, 2013
Try another to see if it will pick up also check cable
Go the desktop, right click with mouse and select properties (if it is XP) then it will open Display properties -->
There you need to go to Screen saver and then to Power option
Disable any power off mode on/ Sleep mode. It will solve your problem.
Please rate the solution. Otherwise let me know for further assistance.
LG Flatron... | Answered on Oct 27, 2013
In LG w1943sb monitor, screw is not used. .In this type 'press-lock' of cover is used. Did you have opened IR remote control, most remote control also used as this monitor's lock, and you can open with a flat screw driver.
LG Flatron... | Answered on Sep 29, 2013
Press F8 during boot and then choose safe mode when menu displays Use up down arrow keys and enter. Sometimes it take longer to load in safe mode for some reason.
LG Flatron... | Answered on Aug 31, 2012
Go on Option or Menu ,Pwer saving mode then change the setting the way you want them.
LG Flatron... | Answered on Sep 01, 2011
This is the technical fault i.e any IC damaged. better take it to the service center or any technician.
LG Flatron... | Answered on Aug 29, 2011
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
130 questions posted
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
monitor comes
  • Computers & Internet
