20 Most Recent Kenwood Vintage Kac-820 2ch. Old School Amp Questions & Answers
Any video file that is .avi requires codecs. Most players don't have a comprehensive list of codecs on their chips though they have divx and xvid on many devices these days. divx and xvid are codec types of .avi. Types such as .mpg or .mpeg or mp3 or mp4 are older and more compatible with most equipment. mkv may not work
Kenwood Car... | Answered 3 hours ago
check all the wiring at te back the push and hold reset button for ten second and try power again
Kenwood Car... | Answered on Nov 05, 2019
push and hold rest bull with a small pin and the unplug unit for ten second then try power up again
Typically those car radios have an embedded (on circuit board) chip which is a flash EEPROM type memory. And this chip stores data which was programmed even if power is removed to the system. It also cannot easily be erased. They engineer this on purpose because any workaround to there anti theft system would defeat the purpose of having it so. Um I'm 99% certain without that code you basically have a brick which won't power on. And nothing you can do can change that. Perhaps and engineer or something could replace the chip or I have heard of ways to wire in and basically short certain leads causing the chip to delete it's memory without actually destroying it but that is engineer level stuff. Buyer beware I would definitely get a refund on that. A quick Google search of Kenwood 6140 password comes up with this to confirm what I already know about this technology. Also with 4 digits there are 10000 different combinations.
https://www.manualslib.com/manual/705744/Kenwood-Dnx6140.html?page=74
Kenwood Car... | Answered on Oct 31, 2019
Hi John Anderson, indicate the model of the Kenwood stereo that you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola John anderson, indica modelo del est?reo Kenwood que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Kenwood Car... | Answered on Oct 09, 2019
Download the model number, then put operators manuel.
Kenwood Car... | Answered on Aug 26, 2019
Hi Karen, you can download the manual from the internet to a USB memory and then print it or send it to print on the sheet size you like best and you would already have it on paper
I send you the link to download
Hola Karen, puedes descargar el manual de internet a una memoria USB y luego lo imprimes o lo mandas a imprimir en el tama?o de hoja que mas te guste y ya lo tendrias en papel
te envio el link para que lo descargues
http://manual.kenwood.com/files/509335ef87853.pdf http://manual.kenwood.com/files/509335dbbeee5.pdf
Kenwood Car... | Answered on Aug 24, 2019
Hi Lisa, as you say, it is very likely that the Laser reader may be dirty or the reader's progress locked
Consult a specialized technical service
Hola Lisa, por lo que comentas, es muy provable que pueda estar el lector Laser sucio o trabado el avance del lector
Consulta a un servicio tecnico especializado
Kenwood Vintage Kac-820 2ch. Old School Amp Logo
2 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
get instruction manual kenwood kdc 400
  • Car Audio & Video
