20 Most Recent Motorola Mobility RAZR V3 Questions & Answers
Hello PattiPaige,
The feature to disable answering the phone when you open the flip can be found under:
Settings & Tools
- Call Settings
- In Call Setup
- Answer Options
- Set option to Off
This will disable the flip from answering the call when opened.
As for increasing the font size, i don't believe there is an option to do so. If I become aware of one I'll try to get back to you on.
Hope this helps,
cHiPz
Motorola... | Answered on Aug 22, 2019
sorry fixya can not assist with this . try the manufacturer
Motorola... | Answered on Jun 09, 2019
I would search google for "file recovery" software and run that on your microSD disk, just like you would a floppy or hard disk and see if it will find anything.
Motorola... | Answered on May 27, 2019
What to do if - "Contact Service Provider", "Tampert Alter", "Wait before enter special Code" message is displayed: If after inserting a simcard from a different provider you notice the message "contact service provider" or any of the messages above, you will need to leave your phone on, at that "contact service provider" screen, for 1-3 hours. Just let it sit on the screen and dont touch any buttons during that time. It will then switch to something like "enter subsidy password", and you can then enter your code.
Motorola... | Answered on Oct 13, 2018
I plugged my phone up and all of a sudden got the message "Unable to charge" on it. I changed chargers (i had an extra one), i changed batteries (i had an extra one), and i swapped every combination imaginable.
My solution....
My Razr's plug has an opening to plug the phone that resembles a person's navel, and it got dirt and dust bunnies in it while it was in and out of my pockets. I was able to take an old tooth brush (or your new one if your really desperate), and got a can of office duster that you use to clean keyboards. Turn the can of office duster upside down for a second while you are spraying it and liquid will come out as you are spraying the connector. Immediately after that, use your toothbrush to work it inside the dirty connector to free it from anything that will keep it from making good contact. Then, hold the can of office duster upright and it will only spray air... and blow the connector free of anything that you loosened with the brush. Repeat this process if after all this it still doesn't work... because you have a REALLY REALLY dirty connector if it doesn't work after the first try.
Motorola... | Answered on Apr 23, 2018
Possibly that particular SIM and your Motorola V3 do not play nicely together. Separate them and everything works.
Motorola... | Answered on Feb 20, 2018
Contact your existing carrier of the Helpdesk of the manufacturer, I think could be ya best bet
Motorola... | Answered on Feb 14, 2018
you will have to go into your call settings and select call barring and add the number you want to block
Motorola... | Answered on Jan 30, 2018
Which Country Network Lock now?
You can get the Unlock code and Unlock Instructions at
moz-screenshot-7.pnghttp://www.theunlockspot.com/motorola-razr-v3/rs10wp9/
follow the Instructions and Unlock it step by step:
Motorola RAZR V3 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Motorola RAZR V3 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola RAZR V3 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola RAZR V3 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola RAZR V3 is locked to.
WARNING: If one of theses messages appear :
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola RAZR V3 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Motorola... | Answered on Jan 16, 2018
You can report the number to the authorities, or
Yes, sort of: go to Settings->Security->Enter lock code here if you've created one(otherwise ignore this step)->Limit Use->Restrict Incoming Calls
From this step, you'll have to choose to restrict incoming calls from anyone NOT in your Contacts <Except Contacts>. You'll still get the voicemails and notifications of who called, but unwanted callers will go right to voicemail and you can call them back whenever you are ready.
try press *#power key at the same time if you see your phone in bootloader mode. your phone can be recover. let me know so i can give more tips
Motorola... | Answered on Dec 28, 2017
Your phone may be network carrier locked! Means it will only on one network.
Contact you previous carrier & request an unlock.
You will have to give them the Imo No of the handset
Unfortunately there is no such thing as a Motorola unlock generator or free motorola unlock code, as such there is no way to unlock your Motorola Razr-V3 for free, Motorola randomly generate the codes so they have full control over unlocking Motorola Razr-V3, However you can get the unlock codes To Unlock Motorola Phones FAST and at very reasonable prices from the given websites.
www.motounlocknow.com/motorolav3.htm
www.cell-unlock.com/motorola-v3-razr-unlock.htm
Hope my info helps you....
Thanx for using fixya......
Motorola... | Answered on Dec 26, 2017
get a lawyer involved
take it to a phone / repair shop for a diagnosis and quote then present that to the lawyer to get action from motorola
Motorola... | Answered on Dec 09, 2017
I don't know whether the free unlock code will solve the issue in the phone. To get the free instructions of the phone, i recommend you to visit the site MobileUnlockGuide.com where you will get the solution for your phone.
http://mobileunlockguide.com/
Motorola... | Answered on Dec 08, 2017
It has water inside...put the phone in a bag of rice for a few days...It will draw the moisture out..Take your covers off also
Motorola... | Answered on Dec 06, 2017
Motorola Mobility RAZR V3 Logo
9,392 questions posted
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
RAZR Motorola Mobility
  • RAZR Motorola Mobility
Most Popular Question
being harrassed one caller
  • Cell Phones
