20 Most Recent Hoover Elite U5061-900 Bagged Upright Vacuum Questions & Answers
in the front on the bottom you will see 2 slots put a small screwdriver in and push up on the clips in the slots and the bottom cover will come off .be careful not to break the clips.just push up on the clip and pull out on the cover at the same time.before you replace the belt clean the old rubber off the motor shaft first ,if you don't the new belt won't last very long
Hoover Elite... | Answered on Jan 13, 2015
Every Hoover I've had has two screws on the bottom that you remove.  Then you lift off the cover and you pry out the brush roller. The new belt goes with one end on the motor shaft and the other end on the humped roller part on the brush roller.  Good luck it's a bit of a struggle but you can do it.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Hoover Elite... | Answered on Apr 27, 2014
Any coarse thread screw about 1/2" long will work. There's no real "threads" inside, its just cut when they put the screws in at the factory.
Hoover Elite... | Answered on Apr 11, 2013
With the hood off you should see a metal shaft sticking out from the motor about 2" (directly below the handle) this is what turns the brushroller. It should be fairly obvious. I've never seen one break, so thats unlikely. Unless the motor housing melted. It only requires taking off the hood to change a belt on them.
Hoover Elite... | Answered on Aug 30, 2012
Pry the 4 plastic knobs holding the hood on, outward from underneath. There will be a little screwdriver and an arrow on the bottom pointing to each one. Lift off the hood and you'll be able to see whats going on. Good Luck.
Hoover Elite... | Answered on Aug 28, 2012
Your best bet is checking the owner's manual.
Hoover Elite... | Answered on May 12, 2012
Yes it is the cam actuator spring. It keeps tension on the height adjustment wheels. Hope this helps.
Hoover Elite... | Answered on Apr 14, 2012
The bag chamber is not sealing properly. Turn on the unit again, block up the hose with one hand and feel around the bag door to determine where the suction loss is coming from. It could be near the bottom of the door where one of the tabs have not been inserted properly. Good luck!
Hoover Elite... | Answered on Jan 25, 2012
Not sure who helped you, was it me?
Go to this URL:
http://www.hoover.com/pdfs/manuals/U5167900.pdf
In figures 3-21 to 3-23 you will see how the new belt is attached and they point out where the motor spindle is. If you have problems, please contact me.
If you find this information to be of help, I would appreciate a rating in the FixYa system. Thank you. Paul
Hoover Elite... | Answered on Sep 23, 2010
Hoover Elite U5061-900 Bagged Upright Vacuum Logo
Popular Tags
53 questions posted
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
need know install belt hoover
  • Vacuums
