20 Most Recent Vizio L32 32 in. LCD HDTV Questions & Answers
Can we talk about how it says “not support” and not “not supported” that bothers me more then thinking about the TV being broke.
I just turn my cable box off then back on and it resolves the issue for a while.
Vizio L32 32 in.... | Answered on Apr 24, 2019
The other poster was right, there is a zoom button on my CABLE REMOTE and once I pressed that my problem was solved. It's funny none of the techs knew that, at either Vizio or Comcast.
Hope this helps.
Vizio L32 32 in.... | Answered on Feb 17, 2019
Just epoxy to keep them together. Nothing to with the operation of the set. I've seen several sets made like that, with no idea why they would. Nothing to worry about.
Vizio L32 32 in.... | Answered on Feb 11, 2019
I have a Vizio VX37L that i purchased on 12/26/08 and I had the same problem by 1/4/09. My five year old son loves to futz around with buttons and switches and he somehow enabled closed captions from the front of my Motorola digital cable box (I had it hooked up to the Vizio via HDMI 1.)
What you need to do is turn off your cable box and leave the Vizio on. Hit the "Menu" button on the front of the cable box and that should bring up a setup screen on your TV. Using the down cursor button on the front of the cable box, go down to the "Close Caption" section on the setup screen. It probably says "Enabled." Click on the right cursor button to disable CC and you should be good to go.
Vizio L32 32 in.... | Answered on Feb 03, 2019
Here is the Remote info
  • VIZIO Universal Remote Setup ' VIZIO www.vizio.com/remote-setup Point the VIZIO remote control at the ... Click the following link to view a complete listing of codes to program your universal remote. ... TV; Audio; VIZIO ...
  • Universal Remote Codes - Vizio cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf · PDF file UNIVERSAL REMOTE SETUP ... Find the programming code for your TV (or device) in the ... Point the VIZIO remote control at the device and press
  • Vizio Universal Remote Codes - TVremoteCodes.net tvremotecodes.net/vizio.html Vizio Remote Codes for TV, DVD, VCR, ... Uverse Remote Codes; Comcast Remote Codes; Dish Remote Codes; Universal Remote Codes; Apple Remote Control; ... VIZIO ...
  • The company started in 2002 as V Inc. by William Wang, Laynie Newsome, and Ken Lowe with $600,000 and three employees. In 2006 the revenue was estimated around $700 million, and in 2007 it was estimated to have exceeded $2 billion. VIZIO is known for aggressively pricing their HDTVs against major competitors.[2]
  • On October 19, 2010, VIZIO signed a 4-year contract to sponsor college football's annual Rose Bowl game in Pasadena, California, beginning with the 2011 Rose Bowl presented by VIZIO and ending with the 2014 VIZIO BCS National Championship Game.[3] When the Rose Bowl contract ended, VIZIO signed a contract to sponsor the Fiesta Bowl making the official name the VIZIO Fiesta Bowl.
    As of 2012, VIZIO has over 400 employees.[4] About half work at its headquarters in Irvine, California, in engineering, design, sales, and operations, while the other half are employed at a call center in Dakota Dunes, South Dakota.[4][5]
    VIZIO also manufactures its products in Mexico and China under agreements with ODM assemblers in those countries.[6]
    Her eis
    Vizio L32 32 in.... | Answered on Sep 10, 2018
    Simple Fix
    I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
    Here is the fix:
    1. Turn on TV
    2. With remote, press the Menu Button
    3. Go to Antenna Menu
    4. Select Auto Search
    Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
    5. It should be done, your remote will work perfect along with the TV channel buttons.
    Vizio L32 32 in.... | Answered on Jun 24, 2018
    The TV probably needs a firmware update. They are needed frequently, and if not up-to-date you will get problems like that. Using the menu system, select "update." Note: They do not recommend updating via wireless because if anything goes wrong with the connection, your system is toast. Best bet is to download the update via computer onto a USB drive, then insert the usb drive into the TV (it may have a specific USB location for updates; check manual), and during the update process you will be asked whether to update via internet connection or USB drive. Select USB drive for "location" of update. (Go to Vizio web site, enter model number, and download the latest Firmware Update for your TV. NOTE: Do not do _anything_ with the TV during the update process... wait until after it says "complete.")
    Vizio L32 32 in.... | Answered on Apr 03, 2018
    Could be power supply failure
    Vizio L32 32 in.... | Answered on Jan 19, 2018
    The EEPROM on the main board is damaged, you may change the main board, or change the EEPRON on the main board (You may find one on EBay cost $15.00 to $25.00)
    Vizio L32 32 in.... | Answered on Jan 16, 2018
    2008?. Well anyway, Do you have a power light, if flashing... panel needs replacing...if no light...power board needs replacing
    Vizio L32 32 in.... | Answered on Jan 14, 2018
    Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
    http://electronicshelponline.blogspot.com/ //
    Vizio L32 32 in.... | Answered on Jan 11, 2018
    Hi ,
    Get a technician check the ports on the video card if there are dry joints if ok change the video/audio card .
    peace .
    Vizio L32 32 in.... | Answered on Jan 10, 2018
    English!!
    Vizio L32 32 in.... | Answered on Dec 14, 2017
    Did you test the remote with your cell phone camera?
    Vizio L32 32 in.... | Answered on Dec 11, 2017
    this might help, posted 8 years ago.
    http://www.fixya.com/support/t13824541-orange_vizio_light_comes_but_tv_wont.
    if you want to fix the power board yourself i'd try Aliexpress for the parts IC901= Off-Line SMPS Current Mode Controller (ICE3B1565), you might also consider the surrounding/connecting parts to that chip as being damaged... particularly the Zener diode.
    Vizio L32 32 in.... | Answered on Nov 23, 2017
    Vizio L32 32 in. LCD HDTV Logo
    2,362 questions posted
    Top Vizio Televison & Video Experts
    Tony Nguyen
    Tony Nguyen
    Steve Allison
    Steve Allison
    Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
    View Most Popular
    • Vizio Televison & Video
    Most Popular Question
    activate vizio
    • Televison & Video
