20 Most Recent Canon 2 Ir3300 Ir3300i B/w Copier/ Network Printer & Fax Questions & Answers
replace the trancefer roller or hvt power supply board
Canon 2 Ir3300... | Answered on Apr 08, 2019
on a server ?
Make sure the networked printer is turned on and connect to the Internet using an Ethernet cable.
Click "Start" on the server computer and click the "Printers and Faxes" icon.
Click "Add a Printer" on the left side of the window.
Choose "A Network Printer" from the pop-up window, and click "Next."
Type in the exact location or Internet Protocol (IP) address of the networked printer, and then click "Next."
Select the printer manufacturer and model from the list of driver options. Click "Finish" to complete the printer installation process.
or a home network
Navigate to the Control Panel and click on "Printers and Other Hardware."
Click the printer you want to share in the Printers and Faxes folder. Click on "Share this Printer" in the Tasks Pane or right-click on the printer and select "Properties.
Open the Sharing tab and click on "Share this Printer." Enter the name of the shared printer and click "OK."
Use the shared printer with any computer on the network by navigating to Control Panel > Printer and Other Hardware.
Click "Add a Printer" and browse for the network printer you just shared.
Connect the Printer Directly to the Network.
Plug the printer directly into the network hub or router.
Follow the instructions for setting up the printer for networking provided by the printer manufacturer.
Click "Add a Printer" and browse for the network printer.
hope this helps
Canon 2 Ir3300... | Answered on Oct 08, 2018
Its the serial number board. Someone swapped the main controller out and didn't change the small serial number pcb with it. That board HAS to be returned to the machine or it will not function. Only way to get a new board is through Canon engineering.
Canon 2 Ir3300... | Answered on Sep 21, 2018
Registration of lens home position
Canon 2 Ir3300... | Answered on Jul 12, 2018
you need to enter in service mode and clear error from there
press additional function once
press 2 and 8 at the same time once
press additional function again
service mode should appear in the screen. if doesn't repeat the procedure above
in service mode:
select Copier
select function
select clear
select ERR
press ok.
turn off from main switch and make some copy tests
Canon 2 Ir3300... | Answered on May 12, 2018
i m using canon ir3300 , showing paper jam at left side , but i checked there is no any paper, although there is showing jam. what to do.
Canon 2 Ir3300... | Answered on Mar 31, 2018
Please reset your machine:
Do this:
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code should be gone, and the printer/copier should work again.
Canon 2 Ir3300... | Answered on Jan 04, 2018
E014 is strain on the fuser motor. Is the lower roller cleaning roller clean? A build up of waste toner on it and could be sticky/tacky and causing friction. Take it out and clean it or replace it.
Canon 2 Ir3300... | Answered on Jan 03, 2018
hi. you need to configure from service mode
Canon 2 Ir3300... | Answered on May 25, 2016
hi that error indicates there is a problem with the hard drive unit
maybe corrupted software of damaged HDD
Canon 2 Ir3300... | Answered on Apr 26, 2016
how i do for download mode for canon ir 3300
Canon 2 Ir3300... | Answered on Mar 24, 2016
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR3300&code=E100-0001
Canon 2 Ir3300... | Answered on Mar 21, 2016
Canon 2 Ir3300 Ir3300i B/w Copier/ Network Printer & Fax Logo
142 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon ir3300 showing paper jam in 2nd
  • Office Equipment & Supplies
