20 Most Recent Hoover AAA140 Front Load Washer Questions & Answers
I have hoover vision hd 1400 aaa
In proble stain blaster
I oll redy clean thing and check water vest pipe
Nothing to blocking
Hoover AAA140... | Answered on Sep 09, 2018
Hi Steven,if its not having a burnt smell it must be just water vapor,I Iive in this tropical part of the globe so we don't see much of this vapors coming out of our washing machine after spinning..I hope its just some kind of temperature difference and not an expensive problem.Its ok to tell us more of what you are observing,have a nice day amigo !
Hoover AAA140... | Answered on Apr 21, 2015
sometimes small objects like coins and buttons that came off our cloths makes the noise.See if something would fall if you turn it upside down,that is the simplest thing to do without using a tool.Good luck
Hoover AAA140... | Answered on Mar 08, 2015
Hi Agira,here's a link to your problem code.
Hoover AAA140... | Answered on Feb 16, 2013
Possible that the program has to be reset, remove power for some time and allow the residual voltage to drain off by pressing on all panel buttons. switch on and try again, if not check with another program cycle before the controller is suspected..
Hoover AAA140... | Answered on Jul 03, 2012
Possible this can be the brushes or the bearings and you can get some tips from the links below:
motor bearings
motor brushes
could be your filter is blocked or the pump has jamed try cleaning filter first
Hoover AAA140... | Answered on Apr 21, 2012
Being from the UK I am amazed that vendors elsewhere seem not to supply manuals automatically with each machine!
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Hoover AAA140... | Answered on Sep 04, 2011
'E02' decodes as 'fill time-out (slow fill)'.
If you have checked that the water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking the water inlet filters. Turn the taps off and remove the water hoses at the washer end. Inside the inlet ports there are normally little filters which should just slide out. Clean if necessary and replace them and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning water control valve (hot or cold- difficult to judge without being there). Sorry but it needs replacing and a service call ;-0(
Thanks and good luck,
John C
Hoover AAA140... | Answered on May 07, 2011
Hoover AAA140 Front Load Washer Logo
91 questions posted
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Washing Machines
Most Popular Question
when emptying machine after spin water
  • Washing Machines
