20 Most Recent Hoover Nextra HNF 3157 Front Load Washer Questions & Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Hoover Nextra... | Answered on Jun 25, 2018
A lot of times the bearing wear... they are placed around the drum and maybe sticking.. If it squealed or made funny noises check those first. It would be like putting on a break and trying to drive a car.
Hoover Nextra... | Answered on Feb 20, 2018
possibly a faulty "off-balance" detector, but not sure...try to purposely make it go off balance during wash...maybe a few pairs of sneakers?
Hoover Nextra... | Answered on Jan 20, 2014
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Hoover Nextra... | Answered on May 01, 2012
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Hoover Nextra... | Answered on Sep 01, 2011
the hook faces away from the center of the door.
The handle goes around that.
The spring goes around both, on the inside of the hook, facing the center of the door.
Hoover Nextra... | Answered on Feb 28, 2011
Problems with a washing machine not spinning or not draining are often inter related..
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Hoover Nextra... | Answered on Feb 14, 2011
Hi, welcome to FixYa. If the belt continually slips off you may want to try tightening the belt by way of loosening the bolt on the motor bracket usually gold or brass in color and pull the motor down slightly but firm and refasten the bolt. Either that or the belt itself has become too worn/stretched and just needs to be replaced. Also insure the drive pulley is tight and not "wabbling" in a manner that would throw the belt off. In extreme cases it can also be caused by excessive load size, improper detergent/too much detergent or unstable footing. Hope that helps. Thanks for choosing FixYa. Good luck going forward. macmarkus :)
Hoover Nextra... | Answered on Aug 18, 2010
Hi
Please check the bellow link for the diagram..and the the door lock assembly is circled in the diagram….
http://ww2.justanswer.com/uploads/Techdesk/2009-01-08_084629_31000603E.pdf
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Hoover Nextra... | Answered on Jul 09, 2010
Hoover Nextra HNF 3157 Front Load Washer Logo
Popular Tags
49 questions posted
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
jimorris77
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Washing Machines
Most Popular Question
washer will spin but
  • Washing Machines
