20 Most Recent Brother Ink for Dcp-6690cw and Lc-1100 Questions & Answers
replace the cartridge, machine see the cartridge as new, reset machine thinks its new when in reality its old causes code and image issues
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Brother Ink for... | Answered on Jun 13, 2015
Print impossible messages or similar almost always indicate a full waste ink tank. These can be emptied and the purge counter reset, but it is a messy pig of a job. Do a check on google or similar for instructions and demos,
e.g.
http://printercartridgesinkuk.blogspot.co.nz/2014_06_01_archive.html
and disassemble the machine to get to the waste tank mounted (usually) behind the cartridge bay. Clean and dry the pads, then put it all back together and run the reset code.
Brother Ink for... | Answered on Feb 06, 2015
try to reinstall drivers and install new ones. Se if copy function does work, If not. look for an
Brother Ink for... | Answered on Jul 20, 2014
Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
Pull out all cartridges and take a flash light, look inside the printer, in the upper-back part you'll see black pins, check if are they clean and embedded, if black pin in even a bit loose, you'r need to solder a new pin on the PCB
Error 70 on Brother printers usually means the encoder strip behind the carriage assembly is out of position or very dirty. I would remove the top cover to correct the error and/or you might also find a scrap of paper either on the extreme right or left stopping the carriage from moving properly.
Brother Printer Support
Brother Ink for... | Answered on May 11, 2014
Sir/Madam
If your printed pages have a horizontal line in the text or graphics (as shown in the illustration below) or blank text, some of the nozzles may be clogged and need to be cleaned
Go to Section 2 for instructions on how to print the Alignment Check sheet and adjust the print alignment.
Section 1: Checking the print quality and cleaning the print head
  1. Print a Print Quality Check Sheet.
    1. Press Menu.
    2. Press the UP OR DOWN ARROW key or the dial pad to choose Ink Management and press OK.
    3. Press the UP OR DOWN ARROW key or the dial pad to choose Test Print and press OK.
    4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and pressOK.
    5. Press Color (Colour) Start. The machine begins printing the Print Quality Check Sheet.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  3. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    (A) One or more complete blocks of colors are missing:
(B) Most of the short diagonal lines are missing from one or more color blocks:
(C)Some parts of the short diagonal lines are missing from one or more color blocks:
  1. The display will then ask you if the print quality is OK for black. Press the DOWN ARROW key or 2 to choose Nofor black with the problem.
  2. The display will then ask you if the print quality is OK for Color. Press the DOWN ARROW key or 2 to chooseNo for color with the problem.
  3. The display will then show Start Cleaning? Yes No.
    Press the UP ARROW key or 1 to choose Yes and the machine will start cleaning the color ink cartridges.
  4. When the machine completes cleaning the print head, press Color (Colour) Start. Another Print Quality Check Sheet will print.
  5. Repeat the cleaning and the quality check process following the Step 4-7.
  6. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
9. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times). If you do not see any further improvement after that, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times). If you still do not see any improvement, please contact Brother Customer Service from "Contact Us."
10. Press Stop/Exit.
Section 2: Checking the Print Alignment
  1. Press Menu.
  4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and press OK.
  5. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  6. By reviewing this Check Sheet, you can determine if the alignment needs adjustment.
  7. Examine the 600 dpi and 1200 dpi test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 dpi and 1200 dpi most closely matches the 0 sample, press the UP ARROW key or 1 to choose Yes.
    If one of the other samples is a better match for the 0 sample, press the DOWN ARROW key to choose No. The display will then prompt you to choose the sample that most closely matches the 0 sample for 600 dpi and then 1200 dpi.
  8. Press Stop/Exit.
If the print quality continues to be poor, go to Section 1 to clean the print head.
If your question was not answered, please check...
Improve poor print quality Brother
Or
If You Still need Brother Printer Help then I suggest You follow Us On For: Brother Printer Support
Brother Ink for... | Answered on Feb 14, 2014
Sir/Madam
It's Very easy to reset counter in brother Printer,I suggest You watch YouTube video For Your Brother Printer Problem,I Hope You resolve and get all Brother Printer Help after watching this video URL Link below:
How to Reset Purge Counter on Brother DCP J315W Printer
Or
In case You still need Help I suggest You Follow Us On:
Sir/Madam
Hear is the solution For Your Problem,Just Watch The Video On And Fix Your Brother Printer Issue,
www.youtube.com/watch?v=BxbJbXf1u9w
or Go to Brother Official Web Site ->FAQ's & Troubleshooting ->Error Messages (LCD, PC) or LED Lights > faq002555_00
I Hope By Now You Fixed Your Problem Brother Printer Support
Brother Ink for... | Answered on Jan 09, 2014
my DCP 6690 printer causes problem unable to clean 46 how can i solved this ..............
Brother Ink for... | Answered on May 18, 2013
Machine Error 77 shows a mechanical malfunction within the printer. Sometimes the ROM detects a vague error caused by a surge power or power outrage. It is often possible that nothing is wrong but your system has detected a false error. To make sure that the error is not vague, you need to check whether the surrounding of the machine is clear or not. If the fan gets blocked by any means, you may have to face this grim error.
Effective Solutions to Fix Brother Printer Machine Error 77:
If you are being unable to track down the possible solutions for the error, this blog is perfect for you. Stay calm and read out the blog or else connect with Brother Printer Repair Services to get to the root of the error.
Mechanical malfunction is a curse for your Brother Printer. It slows down your system and gives an abrupt error in unexpected situations. But don't worry as Brother Printer Tech Support Number +1 888 597 3962 is here to back us. They will help you to Fix Brother Printer Machine Error 77 and other such issues
Whenever this error appears, the first thing that you need to do is to open the front panel.
Now take the toner out of the printer.
After doing so, close the panel and move forward.
A message will appear, asking you to open the panel door.
When the door is opened, replace the toner.
Grab 24*7 Brother Printer Support Phone Number For Instant Help:
Whenever and wherever the Machine Error 77 starts troubling you, there is nothing to freak out. With our Brother Printer Support Phone Number +1 888 597 3962 support and guidance, critical to critical errors are easy to resolve. No matter how time taking and how complex the error is, we are at your back 24*7. Hence dial out the number and have the most reasonable help at your desk.
For any kind of technical help during the process contact, Router Technical Support team to get an instant solution. They are available 24/7. Call Now ?+1 888 597 3962 for any Support.
More Info - https://www.customersupportcare.com/brother-printer-support.html
Brother Office... | Answered 6 hours ago
Brother Ink for Dcp-6690cw and Lc-1100 Logo
13 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
unable print 70
  • Office Equipment & Supplies
