20 Most Recent Whirlpool Duet GHW9150P Front Load Washer Questions & Answers
Water Temperature Sensor Error - Check the Water Temperature Sensor,Heating Element and Element Relay.
If during the water heating step in wash cycle,the water temperature sensor(NTC) value is out of range,or the heating element circuit has failed,the F05 error code will be displayed - Check connections to
the Sensor,Heating Element and Relay.
Whirlpool Duet... | Answered Yesterday
Hi
Its a simple procedure to reset the Whirlpool Duet front load. Please press and hold the END OF CYCLE button for 15 seconds to reset. Please get back to me if you have any other questions.
Kevin
Whirlpool Duet... | Answered on Feb 12, 2019
f8 is shown when the heater circuit is on with no water in.. it doesnt do it when you unplug the pressure switch because your disabling the heat protect circuit
THE BOARD IS PROBABLY FAULTY
F08 indicates pressure switch stuck on full.
Unplug the appliance from the wall socket.
Take the top off the machine.
Locate the pressure switch, you can identify it by the thin tube attached to it.
Take the tube off, blow down this tube as hard as you can to shift any blockage or restriction in the pressure chamber. Give the pressure switch a couple of good taps with the screwdriver handle.
Refit the tube and try the machine again.
If still doing it, unplug again and follow the tube down.
This end will be attached to the pressure chamber.
Take this chamber off and thoroughly clean it out, clean out the port into the tub too.
Reassemble and try again.
If after this it's still faulty you'll need to start replacing parts.
I'd suggest trying a new pressure switch first.
Failing this, if all of the above fails to resolve the problem you're possibly looking at a faulty main control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Whirlpool Duet... | Answered on Jan 22, 2019
My pant legs and long sleve shirts twist into a knot, every time. How can I stop this from happening?
Whirlpool Duet... | Answered on Dec 28, 2018
mains filter blown door lock fail main pcd fail appliance doctor
Whirlpool Duet... | Answered on Dec 06, 2018
Try holding in the "End of Cycle"tone button
Whirlpool Duet... | Answered on Oct 10, 2018
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Whirlpool Duet... | Answered on Sep 18, 2018
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Whirlpool Duet... | Answered on Aug 27, 2018
    is the door lock light on?if not the lock switch may be bad, or the board may not be sending power to the switch.a volt-ohm meter must be used to test the system.
    Whirlpool Duet... | Answered on Aug 20, 2018
    F6 code is an issue with the motor drive tachometer.
    Most often this is caused by poor connections at the machine control or motor controller. Locate the main machine control by removing the top panel and the motor control by removing the rear panel. Remove each connector, one at time, and reinstall. If this does not work, you likely have a faulty control.
    E1 means that the thermistor is open and needs to be replaced. The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
    If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
    For replacement parts - head on over to SearsPartsDirect.com - PartSelect.com - or RepairClinic.com and enter in your full model number for a full parts listing.
    Hope helps.
    Whirlpool Duet... | Answered on Jul 21, 2018
    Hello & Welcome to FixYa
    Your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
    Kevin
    Whirlpool Duet... | Answered on Jul 10, 2018
    Hi, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force. Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
    Whirlpool Duet... | Answered on Jun 09, 2018
    Cawnee:
    Thank you for your review.
    We would like to inquire further about your review with you. Please respond back to this email address, Maytag_Reviews@Maytag.com, with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
    We look forward to your reply.
    Thank you,
    Maytag® Social Media Relations
    Whirlpool Duet... | Answered on Mar 09, 2018
    Try looking online for another manual. Or call anyone who sells your machine. Me thinks the solution is simple, but you need to talk to any seller of your machine, and soon.
    Whirlpool Duet... | Answered on Mar 04, 2018
    f-ll is too much soap
    Whirlpool Duet... | Answered on Feb 19, 2018
    the highest water fill cycle for your waher is the clean cycle.it will fill up with 2x the normal amount of water in this cycle than any other.look for a cut or wrinkle in your door boot(grey rubber outer ring that seals between door and boot)if you find one,only fix would be to replace door boot.also clean inner door glass that comes in contact with door boot ring,any hard water build up or sediment(dog,cat or human hair)will break the seal and allow it to leak.good luck
    Whirlpool Duet... | Answered on Feb 15, 2018
    Hello, the F13 means "Dispenser Circuit Error", if the dispenser motor is not able to be driven to its proper position.
    Check the following:
    1. Check mechanical linkage from dispenser motor to the top of the dispenser.
    2. Check wire harness connection to the dispenser motor and Central Control Unit and lastly
    3. Check dispenser motor.
    Thanks
    Whirlpool Duet... | Answered on Feb 12, 2018
    Whirlpool Duet GHW9150P Front Load Washer Logo
    11,376 questions posted
    Sal De
    Marvin
    Marvin
    jimorris77
    View Most Popular
    duet Whirlpool
    • duet Whirlpool
    Most Popular Question
    whirlpool duet washer after problem
    • Washing Machines
