20 Most Recent Nikon COOLPIX S5 Digital Camera Questions & Answers
When electronics on a Digital Camera playa up , you will need a local Camera Repairer to take a look,
Nikon COOLPIX S5... | Answered on Nov 06, 2017
Time for a new camera, the cost to have it exchanged by Nikon is near the cost to replace.
Nikon COOLPIX S5... | Answered on Jul 11, 2017
did u try with a new set of batteries.
is it totally dead or getting off after getting ON for few seconds.
plz give info more in detail tat will assist me in helping u more specifically.
Nikon COOLPIX S5... | Answered on Nov 22, 2013
well maybe there is the lince stucked what you can try plugg it to a usb cable and that to a extern cable to the charger cable for usb once you see the light you take the usb cable out of the fotocamera should open now . but propably the fotos have on the side some damage -
Nikon COOLPIX S5... | Answered on Apr 17, 2012
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Nikon COOLPIX S5... | Answered on Sep 06, 2011
Your best bet is to send the camera back to Nikon for repair, unless you feel confident ordering a new screen and placing it yourself.
Nikon COOLPIX S5... | Answered on Mar 06, 2011
It is possible you have the display turned off... Some cameras allow you to do this to save battery.
Nikon COOLPIX S5... | Answered on Jan 27, 2011
The camera's ccd, the image sensor , is either faulty or has become disconnected. This is a fault that can't be fixed by fiddling with the settings. If the camera is under warranty, then return it for repair. If it is not, it may cost more to repair it than to replace it with a new and better camera. They get cheaper and more capable every year- don't spend too much restoring an old model.
Nikon COOLPIX S5... | Answered on Dec 27, 2010
If you want to do the replacement yourself, you can order the part from
http://uscamera.com/636-116-3392.htm
Nikon COOLPIX S5... | Answered on Nov 10, 2010
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
Nikon COOLPIX S5... | Answered on Sep 29, 2010
If by "the shutter" you mean the lens cover, then you have a lens error fault. If you really do mean the shutter then the shutter assembly is not user serviceable and you have to decide whether to get the camera repaired or to replace it.
Assuming you mean the lens cover then it's such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Nikon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Nikon COOLPIX S5... | Answered on Sep 26, 2010
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Nikon COOLPIX S5... | Answered on Sep 11, 2010
Press up/down on the multiselector to change views. It's in the section under Playback.
Nikon COOLPIX S5... | Answered on Feb 15, 2010
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Nikon COOLPIX S5... | Answered on Aug 12, 2009
Nikon COOLPIX S5 Digital Camera Logo
45 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
lens error come up when battery out
  • Cameras
