20 Most Recent Konica Minolta bizhub C250 All-In-One Laser Printer Questions & Answers
To print the transmission report:
1. Press the [Fax/Scan] key to display the Fax mode screen.
2. Touch [FAX Menu].
3. Touch [TX Report] on the Set 1 tab.
4. Select how to output the report, and then touch [Enter].
– Default: The transmission report is printed according to the previously specified method.
– ON: The transmission report is printed with each transmission.
– If TX Fails: The transmission report is printed only if the fax could not be sent.
– OFF: The transmission report is not printed, regardless of the transmission result.
Konica Minolta... | Answered on Aug 26, 2019
this is a waste toner box error the waste toner box could be defective or the full sensor is defective i would start with replacing the waste toner box and clean the sensors on the door with some canned air the waste box and the sensors are located inside the lower front door the instructions on how to remove the waste box are on a label on the inside of the door
Konica Minolta... | Answered on Aug 15, 2019
Go into the PDS settings and change tab from single page to multiple page.
Konica Minolta... | Answered on Jul 25, 2019
c250 have error codes C-xxxx make and model????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Apr 20, 2019
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Konica Minolta... | Answered on Apr 19, 2019
Abnormally high toner density detected cyan TCR sensor
Konica Minolta... | Answered on Apr 13, 2019
to what?????????????
check The Transfer Belt or it can be the Black Image Unit . (P9 & P21 normally: black Imaging unit) but P21 can also be refered to Transfer Belt). ..
Konica Minolta... | Answered on Apr 11, 2019
was told this message meant Konica have disabled the machine remotely.
Konica Minolta... | Answered on Apr 10, 2019
machine trouble sevice call [c2558] wat a problam in konica minolta bizhub 164 printer
Konica Minolta... | Answered on Mar 19, 2019
what lamp error
Konica Minolta... | Answered on Feb 18, 2019
Hi this kind of errors how came u should mention frst
may ne after you removed the board and then came ?
or while working suddnetly came ?
please specify
Konica Minolta... | Answered on Feb 07, 2019
Sometimes just open the doors and closing them a few times will work its sensing somethings open ,Make sure all is closed you may have too reinstall drivers. start over read all directions sometimes we get burnt out on trying to get something going give it a break for a bit then try again. could be a firewall or anti virus cause problems to.
Konica Minolta... | Answered on Feb 05, 2019
Are you using a 3rd party image unit???, if so get OEM there are chips on them that copier monitors. The image units are the units below the toner cart. which one is having the problem Y M C or Black, did you re chip them, bad idea. Replace them with OEM cartridge.
Most likely there is paper stuck in the very back behind one of the trays. Take both trays out and see if there is any paper jammed (could be a small piece). Put trays back in but leave them open, turn off the printer, unplug it, wait 5 minutes, plug it back in, turn it back on and push in the trays.
Konica Minolta... | Answered on Sep 24, 2018
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Konica Minolta... | Answered on Jun 26, 2018
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Konica Minolta... | Answered on Jun 22, 2018
Does this happen when copying? Can you print internal copier form meter count etc.?
Konica Minolta... | Answered on Jun 20, 2018
Hope this helps. Make sure you remove the waste tank prior to taking out the transfer belt. Belt is removed by two screws inside right door and sliding the unit out.
Konica Minolta... | Answered on Jun 14, 2018
2. Turn Main Power Switch ON while pressing the Utility/Counter key. (Sub power must be "on" located on side of the control panel)
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
1,252 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
clear error message c 2558 konica
  • Office Equipment & Supplies
