20 Most Recent Ricoh Aficio CL7200 Laser Printer Questions & Answers
ok turn the thing on and then open it up and bingo jumbalio!!!
Ricoh Aficio... | Answered on Feb 07, 2017
I would check to see if the paper is even making it out of the tray. A lot of times, the feed rollers can get dirty, and the printer will display a jam if it doesn't feed in time. If the feed rollers look ok, then I would check and see if the feed rollers are even turning. Sometimes the motor that turns the feed rollers wears out.
Ricoh Aficio... | Answered on Nov 11, 2016
try this press clear mode button then press 107 then hold stop button for 5 seconds. should go into service mode. select 5 mode then 810 follow instruction and then turn copier off then back on .
Ricoh Aficio... | Answered on May 08, 2015
job printing processs colour but CMYK not print on the same position
Ricoh Aficio... | Answered on May 04, 2015
The printer is not communicating with the computer. Recheck the IP address on the printer against which port on the computer is selected. If everything checks out ok then uninstall the printer driver and reinstall.
Ricoh Aficio... | Answered on Dec 30, 2014
yellow developer unit is problem . seal not removed when install or tds sensor could be bad or connector in back broken that it plugs into. I have also had were it will push out toward front. i put a piece of paper between it and the bar that holds everything in place.
Ricoh Aficio... | Answered on Jan 27, 2014
Never ever do a memory clear all on a color unit. As you discovered it changes all the color registration values. This is a very, very complicated adjustment and very time consuming. I am a color expert and have been for 25 years now. Unless youre a trained tech youll never figure it out. spend 120 bucks and call a technician sorry..
Ricoh Aficio... | Answered on Nov 23, 2013
you sure you have a booklet finisher it has 3 exits
Ricoh Aficio... | Answered on Oct 02, 2013
In Windows 7, you can right click on the printer under Devices and Printers, then select "Printer properties" (not "Properties"), then under "Device Settings" you can set the "Duplex Unit" to "Installed". Afterwards, you can go back to "Printing Preferences"->"Finishing"->"Print on Both Sides"->Print on Long/Short Edge.
Ricoh Aficio... | Answered on Feb 01, 2013
Ricoh Aficio CL7200 Laser Printer Logo
113 questions posted
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
ricoh aficio 2550 printer
  • Office Equipment & Supplies
