20 Most Recent NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Questions & Answers
Today I am Going to Assist You to Reset Your Netgear Wireless Router To Default Settings.
Let's Get to This Issue First And Understand The Real Problem With Your Netgear Router
There is Mostly Two Methods You Can Be Used to Reset Your Netgear Wireless Router.
  1. Soft Reset Using Netgear Router Dashboard
  2. Hard Reset Using The Reset Key
for more details please visit How to Reset Netgear Wireless Router TechVaidya
I hope this will helps you
NetGear... | Answered on Oct 03, 2019
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
NetGear... | Answered on Jul 05, 2019
I think you might be getting confused.
When it tells you it is static ip it might be referring to your isp connection. I recommend calling reliance broadband and asking them for help with setting up your router . Ask for their support area.
DHCP you might be thinking of could be for your local area network.
By ringing your ISP they will be able to guide you through manually setting up your router and they will know what settings are needed .
NetGear... | Answered on May 15, 2018
Yes google the manufacturer and go to website and download firmware for your model. All Manufacturers have updated firmware for their router and switch products
NetGear... | Answered on Nov 30, 2017
try routerlogin.net
NetGear... | Answered on Apr 13, 2016
1 in a hafe or 2
NetGear... | Answered on Nov 08, 2015
There are many reasons you could loose a connection from a laptop to a router, without giving any information on the model of your laptop, router, wireless setup (Password etc...) it is somewhat impossible to give you an answer.
NetGear... | Answered on Mar 04, 2015
Use Factory Default Reset push button for Restoring the Default Configuration and Password:
25484457-lsnymgrlerdonavibcpcmvzk-1-0.jpg http://www.downloads.netgear.com/files/GDC/WGR614V6/wgr614v6_ref_man_20Apr05.pdf
NetGear... | Answered on Mar 02, 2015
Do not panic yet. It may be that when your laptop was being cleaned up, the ON/OFF button for your wireless radio (if indeed it has such a button) was switched from the ON position to the OFF position. Look for that button on your laptop and if you find it, switched it back to the ON position.
NetGear... | Answered on Dec 26, 2014
If there is a lock symbol that means the wifi is password protected. if you are the owner and forgot your wifi password, you have to reset the router.
if you are in a cafe, please ask the staff if they can let you have access.
NetGear... | Answered on Oct 22, 2014
There is normally a hold the size of a paper clip you need to press and hold it with a paperclip for 30 seconds
NetGear... | Answered on Oct 10, 2014
This is a cut and paste but it saves me time typing.
Find the Netgear router's WPA code on its setup page. Access the setup page by typing "192.168.0.1" into your Web browser's address bar and pressing "Enter." If that number doesn't work, try "192.168.1.1" instead. Type "admin" as the username and provide your router's password. Use "password" if you haven't set a custom password. Click "Wireless Settings" at the left side of the setup page and read the WPA code from the passphrase box on the page.
NetGear... | Answered on Apr 18, 2014
You should be able to set this up by logging into your router 168.1.1 and setting it up on the user page.
If you were to Google this and look for a key ,Google will more than likely find one for you.Caution be careful here ,when doing searches like this you are routed to various sites so make sure you have a good virus protection on before you go to these sites.Also look for key codes or key generators and make sure it is for your version ,check your help on the program and it will generally give you the version number as many games have updates and they only apply to a specific version.
There is little point in posting a question with no real information.
Saying something is "broke", "doesn't work", "can't connect" or that you "need" or "want something" is pointless without ALL the information.
What actual products are you using? Makes, models, connections...everything about your problem is necessary. We are not there with you. We cannot see what is obvious to you. Most problems occur when you try to get something to work with something else. We need to know all the things you are using and doing that ends with your issue.
The issue is the last thing we need not the only thing.
NetGear... | Answered on Apr 04, 2014
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
165 questions posted
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NetGear Computers & Internet
Most Popular Question
reset netgear wgr614
  • Computers & Internet
