20 Most Recent Maytag Atlantis MDE7400AY Electric Dryer Questions & Answers
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Maytag Atlantis... | Answered on Jun 10, 2018
PSUinNC The first thing you have to do is to check in what position is the temperature switch . If the temperature switch is in the "air fluff" position, then the heater will stay "off". If this is not an issue, reset the circuit breaker. The motor needs only 120V to run, but the heater needs 240V and if one of legs is missing, the dryer would not heat. If it did not solve the problem, you have to perform full diagnosis. You will need some simple hand tools and a meter to check a continuity. If you are fillng you can handle it, let me know and I'll give you the step by step instructions. Gendos...post back
Maytag Atlantis... | Answered on Feb 20, 2018
Best guess is that one of the two solenoid coils on the gas valve is faulty, one has two connections and the other has three. Always replace BOTH solenoids even if only one has failed.
Maytag Atlantis... | Answered on Nov 05, 2017
The moisture sensor bar is attached to the bulkhead with 2-1/4 in. screws. 2 wires attach to the sensor bar. Very easy to replace in 5 minutes.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Maytag Atlantis... | Answered on Oct 02, 2017
ON THE ELEMENT U HAVE THE HI LIMIT, THE THERMAL CUTOFF, AND THE OTHER FUSE FOR THE LIFE OF ME AT THE MOMENT CANT RECALL WHATS ITS CALLED LOL BUT SOUNDS LIKE THE ONE THAT BURNED OUT AS THE OTHER 2 ARE HIGHER UP
Maytag Atlantis... | Answered on May 04, 2015
Go to Partselect.com. they will ask for model number and serial number of your dryer. They have every single little part for appliances but better yet they have video's on how to make the repairs. They also have schematics for every conceivable appliance made. the prices are very reasonable and the customer service is top notch!
Maytag Atlantis... | Answered on Mar 05, 2015
Hello there:
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Maytag Atlantis... | Answered on Jan 02, 2015
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Maytag Atlantis... | Answered on Sep 16, 2014
This is not the solution to your exact problem but for those looking for why there timer will not advance and why it keeps running: The usual problem is not the timer but the mosture sensor.
1: Check the mosture sensor light/indicator. If is still shows some mosture or flashes even when the items are dry, you have a mosture sensor problem, probably not a timer issue - luck you.
2: Check if the timer will advance and the dryer will turn off when you have it in the TIMED mode (i.e. 10mins - NOT the more/less dry modes.) If so, then it is indeed a sensor problem.
2: Check that the wires to the mosture sensor have not fallen off (as in my case - a simple repair). The senor is usually two metal bars somewhere near the front part of the inside of your dryer. You may have to take off the door and the front pannel (be sure to unplug the dryer first) to get at the two wires to clip on to the sensor. Clean any lint and make sure they are conneted. If well connected then replace the sensor ($15-$20 and very easy to do).
Maytag Atlantis... | Answered on Jul 04, 2014
Is the dryer heating? If so try using dryer sheets and allow a bit more on the timer, if the clothes are still damp..If the dryer is running properly I see no other way to solve this.
Maytag Atlantis... | Answered on Jun 08, 2014
most probably blower wheel is loose on shaft,need to replace or shaft witch leads to exhaust is blocked by something creating a back draft in dryer
Maytag Atlantis... | Answered on May 29, 2014
anything involving gas have a certified technicien to do it,anything goes wrong your safety is at risk
Maytag Atlantis... | Answered on Apr 14, 2014
Maytag Atlantis MDE7400AY Electric Dryer Logo
569 questions posted
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
blowing lint dust from bottom
  • Dryers
