20 Most Recent Maytag Neptune Washer Questions & Answers
Try unplugging it for a minute and plug back in, that should reset it.
Maytag Neptune... | Answered on Sep 24, 2018
There may be a problem with the Appliance Control Board, or the associated wiring. Power unit down by turning off the circuit breaker(s) for one (1) minute. Power unit up by turning on the circuit breaker(s). Monitor the oven for one (1) minute to ensure the error code does not display again.
Maytag Neptune... | Answered on Apr 25, 2018
It won't spin if it cannot pump out ALL of the water. Check the outlet pump for obstructions and clear. Check pump to see if its pumping.
Maytag Neptune... | Answered on Jun 23, 2017
some doors will release if given a hard bang where the interlock is...at the door catch.........
cheers
Maytag Neptune... | Answered on May 28, 2017
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Maytag Neptune... | Answered on Jun 29, 2015
There's a fill valve combination on most washers. On the simpler, cheaper models they're simple to change.
It's where the hoses connect, it's usually plastic, and there is a hot and a cold valve in the assembly. Hot opens for hot water, cold opens for cold water, and both open for warm water. apparently the solenoid valve on the hot water side has failed and the unit needs to be replaced.
Maytag Neptune... | Answered on May 23, 2014
If the drain pump malfunctions...or is clogged then it will not empty within the time cycle and the unit will time out. the pump in at the bottom of the machine
Check the door gasket/seal for damage. Check to see if the door's mounting brackets are loose by lightly moving the door up/down. Also check the level of the machine to ensure that the frame is not twisted.
Maytag Neptune... | Answered on Apr 22, 2014
Washing Machines Logo
468 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
Neptune Maytag
  • Neptune Maytag
Most Popular Question
14 year old neptune run great except now
  • Washing Machines
