20 Most Recent Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Questions & Answers
The problem is the washer is defective.
Maytag MAH6500... | Answered on Jan 18, 2018
dose the drum spin at all please clarify eric
Maytag MAH6500... | Answered on Jan 04, 2018
I have read that the imbalance/drum problem is a known problem and should be covered under warranty.
also, that the smell is also a known problem and can only be fixed by replacing the outer gasket. Which seems like a waste of time, as how long would it take for the new gasket to smell?
Maytag MAH6500... | Answered on Jun 03, 2017
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Maytag MAH6500... | Answered on Nov 24, 2016
Try unplugging machine and then plugging back in see if that resets it. Also if you still cant get it unlocked there is a emergency latch release. Remove the 4 phillips head screws holding dispenser trim/lid. Now look in in front of (closest to door) now look for what appears to be a weed eater line (it should be green) pull gently and it should release door. Hope this helps get to your sons socks.
Maytag MAH6500... | Answered on Sep 30, 2015
May have a piece of cloth, plastic etc that may be stuck on something between the belt and the drive system, have a look underneath/back to see if anything is there.
Maytag MAH6500... | Answered on Apr 02, 2015
http://homeguides.sfgate.com/maytag-neptune-washer-model-mah8700-troubleshooting-codes-102595.html. Here's the site for Maytag Neptune Washers. You can also find other modes there. Hope this helps. Enjoy.
Maytag MAH6500... | Answered on Feb 16, 2015
Watch this and you will have it done in no time
If you need further help, reach me via phone at https://www.6ya.com/expert/timothy_c6f309c0f75b6f43
Maytag MAH6500... | Answered on Jul 21, 2014
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
185 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
Neptune Maytag
  • Neptune Maytag
Most Popular Question
maytag front loading washing machine
  • Washing Machines
