20 Most Recent Maytag PAV2300 Top Load Washer Questions & Answers
I have a maytag washer and it starts up and starts going then it stop and if i push start again it will go but it keeps doing it what could it be
Maytag PAV2300... | Answered on Sep 09, 2018
I have the same problem with my agitator keeps popping off...I call the company and they said i would have to replace it...I did too put super glue on it like the other person did, My question is how long do you think the super glue will hold because i did order a new one.. wondering if i should send it back or keep it on hand.. It cost $70.00
Maytag PAV2300... | Answered on Jun 07, 2018
is it on a flat surface and is the machine level.they can be adjusted at the wheels
Maytag PAV2300... | Answered on Dec 28, 2017
For the noise I'd be looking at water pump. For the unbalanced issue, probably snubber ring. Pump easy to replace. Snubber ring not so easy.
Maytag PAV2300... | Answered on Sep 22, 2017
Maybe that lid switch. Really hard to say without a model # to see how it's designed.
Maytag PAV2300... | Answered on Sep 21, 2017
All you will need is a 12002213 thrust bearing kit and new belt , the bearing comes with instructions , lay unit on front to do this you schooled not need a transmission
Maytag PAV2300... | Answered on Aug 12, 2017
The symptoms are indicative of a timer failing.
Maytag PAV2300... | Answered on Jun 12, 2017
Blockage (small) at drain filter?
Maytag PAV2300... | Answered on Apr 03, 2017
First thing I would do is replace the belt as the old one may have streched
Maytag PAV2300... | Answered on Apr 01, 2017
check that the drain hose is above tub level
check for faulty program board engaging the pump all the time
Maytag PAV2300... | Answered on Sep 20, 2016
Sounds like the lid switch is bad, replace it
Maytag PAV2300... | Answered on Mar 13, 2016
seems there might be clips at the front edge on the side panels that unclip with a thin putty knife then the top tilts back
Maytag PAV2300... | Answered on Nov 03, 2015
call a service tech
Maytag PAV2300... | Answered on Mar 31, 2015
first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open. if both check ok then next the motor coupler or belt if belt driven.check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Maytag PAV2300... | Answered on Mar 29, 2015
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Maytag PAV2300... | Answered on Mar 22, 2015
Check hot and cold hoses at back of machine incase there connected wrong
Maytag PAV2300... | Answered on Aug 12, 2014
The drain pump on those are fairly common to have problems...
It could be that the washer is not getting all the water out of the tub so the close stay wet. here's a link to the part:
Drain Pump 35 6780
It could also be that the tub is not spinning fast enough to squeeze water out of the clothes... Does it seem to bee spinning well?
Maytag PAV2300... | Answered on Aug 08, 2014
That style of washer has a transmission tube called the "mode shifter" part#WH38X10017 It has a small electrical solenoid that is supposed to shift from the agitate to spin functions... The problem happens when the entire tub remains engaged for the agitation stroke. So you would see the entire tub moving like just the agitator would normally... That causes larger than normal waves that crest and come out the back left over flow tube. You probably need to replace the mode shifter.
Heres the manual for testing...
Appliance Repair Manual ge washer with electromechanical controls and...
and here's a link to the part:
Clutch WH38X10017
Maytag PAV2300 Top Load Washer Logo
855 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
pav2300 agitator bolt keeps coming loose
  • Washing Machines
