20 Most Recent Casio Exilim EX-Z120 Digital Camera Questions & Answers
It happens because some alkaline batteries just don't have the initial surge of power output required to drive all the little motors, the display and so on.
You need lithium batteries, like the 8x Ultimate Lithium.
They are expensive initially, but on average are more economical than the cheaper stuff.
I've tested them on my Kodak Z712 IS, and any owner of this camera knows what I'm talking about.
The best -and cheapest- solution I found, is the rechargeable Li-Ion batteries.
I got 2 batteries and one charger. I'm using one battery, while the other one is charging.
Casio Exilim... | Answered on Jan 10, 2019
Check the memory card and memory card slot. If everything is clean and intact, look to see what size card you are using. The camera may not accept SDHC cards, so try an SD card that is 2GB or smaller.
Casio Exilim... | Answered on Aug 20, 2014
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Casio Exilim... | Answered on Jan 24, 2013
Try the procedures in this tip.
It doesn't matter to the camera what software you have on your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Casio Exilim... | Answered on Jan 05, 2013
The EX-Z120 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with this camera. You need to use SD cards, 2GB and smaller.
Casio Exilim... | Answered on Dec 31, 2012
You may download the manual here.
Casio Exilim... | Answered on Mar 27, 2012
just visit manufacturers website and download it from there
Casio Exilim... | Answered on Feb 17, 2012
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Casio Exilim... | Answered on Feb 02, 2011
I used to have one but threw it out sorry ;\
Casio Exilim... | Answered on Dec 28, 2010
Casio Exilim EX-Z120 Digital Camera Logo
46 questions posted
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
website download
  • Cameras
