20 Most Recent Toshiba Copier Gm 2040 Print Scan Enabler E Studio 520 600 720 850 Printer Questions & Answers
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Toshiba Copier... | Answered on Apr 29, 2019
U need to check or replace below parts:
1. Main Charger
2. T/S block
3. Terminal under T/S block ( with 2 springs)
After changing above still cannot solve the issue, u need to swapped whole process unit for testing...If not process unit problem, then u need to check the terminal on the machine that contact with the main charger unit, make sure the housing no crack...
Toshiba Office... | Answered on Oct 11, 2019
Toshiba Copier Gm 2040 Print Scan Enabler E Studio 520 600 720 850 Printer Logo
2 questions posted
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
f101 error toshiba estudio2040c
  • Office Equipment & Supplies
