20 Most Recent HP Officejet 5610 All-In-One InkJet Printer Questions & Answers
hi, change printer's head carriage assembly.
HP Officejet... | Answered on Jan 10, 2019
To Fix hp 5610 code 0xd05d01001, contact our HP Printer Support Number 1-800-576-9647 (Toll Free)and fix your issue instantly. Our expert is ready to troubleshoot your problem at anytime. So if you are genuinely looking for solution to fix hp 5610 code 0xd05d01001, call us and fell free. Visit: https://hpprinterphonenumber.com/
Is your HP printer having printing problems due to incorrect printer configuration and driver installation? For the quick tech assistance, you can also go to the Printer USA Support, which is an online directory, offering the certified HP toll-free number that is helpful to directly get in touch with the technicians and get your printer problems repaired in no time. HP Printer Tech Support Phone Number HP Printer Help
hp officejet 5610 will not scan. i have wireless system
HP Officejet... | Answered on Nov 28, 2018
You have to make sure the router recognizes the printer and you have the wireless driver installed on your computer.
HP Officejet... | Answered on Nov 18, 2018
make sure the printer is online and the cable is proper.
HP Officejet... | Answered on Nov 16, 2018
when the printer shows cartridge error that means. 1)the cartridges r either faulty .it can be 1 out of 2 cartridges or may be both the cartridges faulty.if this is the case replace the cartridges. 2)it could also be the case that cartridge is not fitted properly if this the case remove the cartridge and reinsert them properly. 3)it could also happen if there is dirt on the printer and cartridge circuit.if this is the caee remove the cartridges and clean both the printer and cartridge circuit.and then reinsert and check.
HP Officejet... | Answered on Nov 05, 2018
Go to generalmanual.com, type in C5180 then click on the type of manual you want, whether it is the users maual or the setup guide, it is free.
HP Officejet... | Answered on Oct 11, 2018
send me and email and I will provide a service manual for you samlong.delta82nd@gmail.com
HP Officejet... | Answered on Oct 04, 2018
reinstall the software through CD
HP Officejet... | Answered on Sep 21, 2018
There is a coder strip that the print cartridges ride on that strip needs to be replaced , they seem to run between 10.00 and 20.00 bucks. It is spring loaded one the side and other is fixed, they are semi easy to do. May take a couple of times. Also do not wipe the strip with a wet cloth -code will come off!
HP Officejet... | Answered on May 12, 2018
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr20
HP Officejet... | Answered on Mar 27, 2018
Windows Vista causes an error with the scan feature of the HP officejet 5610. To work around it use the paint program:
1. open paint program
2. click file
3. click "from scanner or camera..."
4. scan menu opens
from there simly select the type of scan you would like to do and click the scan button
HP Officejet... | Answered on Mar 02, 2018
Check whether the Digital Imaging Monitor is running .
If yes, good.
Now, please open HP Solution Center and setup the destination list .
Double click >> HP Solution Center >> settings >> scan settings and preferences >> scan to .. setup >>
Add all the entries from " available scan destinations " to "front panel destination list " >> click >> ok .
Now, try to scan from the front panel of the All-in-One .
Put your driver into c:\ root and install from over there
HP Officejet... | Answered on Jan 25, 2018
Click on the link and watch a free youtube video on how to scan.
How Do Scan On An HP Officejet J4680
HP Officejet... | Answered on Jan 23, 2018
It appears their are issues with HPSC in newer OSs:
https://support.hp.com/us-en/document/c04740294
I'm not sure if HP is even supporting HPSC anymore. Perhaps you can use this instead (appears to be HP's new one):
https://www.microsoft.com/en-us/store/p/hp-scan-and-capture/9wzdncrfhwl0
I would also have to recommend that you not use Windows XP anymore as Microsoft has not supported it since April 2014. Good luck.
HP Officejet... | Answered on Jan 16, 2018
HP Officejet 5610 All-In-One InkJet Printer Logo
3,270 questions posted
Clive
Clive
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
no scan options say refer device
  • Office Equipment & Supplies
