20 Most Recent Epson CX4200 All-In-One PSC Printer Questions & Answers
Following is the solution for your problem.
Uninstall the printer software after unplugging the printer and remove it from the network , if it in on network.
Download and install the latest drivers from thee Epson webiste for your operating system.
makse sure you are using the admin account to install the software, once installed it will be working fine.
Epson CX4200... | Answered on Jul 15, 2019
thats a mechanical error, better to send it to actual technician.
Epson CX4200... | Answered on Aug 30, 2011
Refill or replace your ink cartridges,
Epson CX4200... | Answered on Apr 07, 2011
If you have a a solid red light showing you will not get any printing done. On the epson printer which red light is showing? Is it the one for the black or the color? Was that cartridge replaced by you? I have actually seen one cartridge's red light glowing and so replace the cartridge. Then the printer goes through a charging sequence and to my surprise another red light is showing, but this time it's the other cartridge, because the printer was already low on that color and the charging cycle emptied that cartridge enough to trigger the light to start blinking on and off. Now suppose it's the same light that is still on even after you replaced the cartridge. Do this: hold the paper in feed button for about 3 seconds. The printhead will move to the left. Lift up the clamp of the cartridge that
has the red light glowing and bring it down somewhat definitively again to lock the cartridge down. There is a microswitch that is reset when this is done that tells the printer it has a new cartridge installed. Sometimes when a cartridge is replaced the switch is not reset if the clamping process is not definitive enough, or it simply needs to be done again. When you've done this push the paper infeed button again to move the head back to park postition.
Good luck,
Epson CX4200... | Answered on Jan 05, 2011
if it is not a genuine ink it will not sense it try to replace it with another one
Epson CX4200... | Answered on Oct 18, 2010
You can download the drivers from here Epson stylish cx4200 all in one Please select your operating system type from the lists available. Good luck. Thanks for using FixYa.
Epson CX4200... | Answered on May 29, 2010
I just Fixed the error of All Lights Flashing on my epson cx4200 printer.
Solution: I Totally unpluged the printer from 110 power source
then waited 3 minutes, then press the On button and let the printer run thru its normal noises during start cycle.
Originally I tried to just turn printer off with the off/on button but this did not ix the problem.
So make sure you TOTALLY disconnect the printer from the 110 AC power source.
Hope this helps.
Epson CX4200... | Answered on Apr 01, 2010
Charlie,
Please consider this:
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Epson CX4200... | Answered on Nov 12, 2009
It's just a dirty feed roller, you have to reach in and wipe the roller that pulls in the paper so it won't arrive late. Wiping with a damp rag should be enough.
Epson CX4200... | Answered on Nov 03, 2009
You cartridge might be leaking somewhere from any point, please check for this.
Regards,
KK
Epson CX4200... | Answered on Oct 30, 2009
Your cartridges either need to be cleaned or re-aligned. Your printer should have these options. Try them. It should work. There could be something blocking the copper pins in the printer, where the cartidge meets the printer. Check to make sure this area is clean and there is no ink covering these areas. Also check that the cartridge is clean also. If this doesn't work, buy a new cartridge. If that doesn't work, I'm afraid you may have to buy a new printer. Cheers.
Epson CX4200... | Answered on Oct 02, 2009
could be something stuck in there
i find this happens when kids are around
Epson CX4200... | Answered on Aug 25, 2009
It means some nozzle is clog. Do nozzle check at head cleaning procedure.
Epson CX4200... | Answered on Jul 22, 2009
If you are using a compatible cart and the printer has twice reported the cart as empty when they are new, chances are there is a problem with the printer. You can buy a chip reseter off ebay for a couple of bucks and try resetting the cart. If the machine still reports the cart is empty you either have dodgy chips on your carts or the printer is having problems reading the chip, This could be caused by a bent pin/contact in the print head cartridge receiver.
Epson CX4200... | Answered on May 14, 2009
31 questions posted
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
all lights printing
  • Office Equipment & Supplies
