20 Most Recent Samsung ML-2510 Laser Printer Questions & Answers
Hi
Whats your operating system?Choose your operating system from the available downloads on the link below:
www.samsung.com/us/support/owners/product/ML-2510
Hope it helps.Thanks!
Ken.
Samsung ML-2510... | Answered on Jun 21, 2019
I know this is an old post, but I thought I'd add this bit of info. I just fixed my ML-2010 by first replacing a torn pickup tire, but it still kept picking up multiple pages. I read a different post where the person traced it to a bad solenoid that was sticking in the open position as he described it. He replaced the solenoid, but on mine the solenoid was working, but I found it was sticking when closed. It is supposed to close and open once at the start of each page. Mine would close and stay closed sometimes until the start of the next page which would, of course, cause another pulse to energize the solenoid. I found it was due to a deteriorated thin half moon-shaped foam pad on the top of the solenoid's electromagnet that would cause the part that gets pulled in to stick to it for a couple of seconds before the spring would overcome the pad's stickiness and release it. I replaced the foam pad with a then piece of sticky-back felt that I cut to fit. When I reassembled it, it worked perfectly.
The way to get to the solenoid is to pull the covers, take the power supply boards off the back(as one unit, attached to a metal baseplate) and remove the panel underneath it, noting the screws and connections along the way. On the side where the solenoid is attached, I also saw a "split" gear that appeared to have a mark showing how they matched together, so be sure to realign the marks if they become separated before reassembly. Beyond that, it was a simple inexpensive repair. As these machines age, I would bet this is a major cause of this issue.
Samsung ML-2510... | Answered on May 06, 2019
Dear
You can try from samsung site.
Printer Support SAMSUNG India
Thanks.
Samsung ML-2510... | Answered on Mar 25, 2019
wellcome in fixya .com
please click on this link where u can find the driver of samsung ml-2519 for vista
Samsung ML-2510... | Answered on Feb 21, 2019
Change cartridge chip r paper pickup sensor
Samsung ML-2510... | Answered on Oct 14, 2018
I just finished fixing my ml-2510 with the identical problem. you can take the pick up rubber and its housing off without removing the shaft. after taking off the front panel and taking out the upper paper tray and the toner you have lots of room to get your hands in there (make sure it's unplugged before you start). two plastic side supports hold the rubber housing in. lift the tab on one and slide it to the side. the housing will now come out . take note of the positioning of all these parts before taking them apart. I sometimes use a digital camera for this purpose. the housing snaps apart and the rubber band slides off. I turned it inside out and put everything back together. works great now (for another year I hope). It's not difficult, it took me about 30 minutes, but be gentle with these plastic parts. I needed a small flat head screw driver and a good lamp. the easiest way is to stand the printer up on its back and reach down inside the hole with the lamp set up over top. good luck.hope this helps.
Samsung ML-2510... | Answered on May 26, 2018
needs a new roller
Samsung ML-2510... | Answered on May 04, 2018
when printing specific pages the valid range is in this format 1,3,5,7,9,11 etc or if printing even numbers 2,4,6,8 etc or if printing specific pages 1,5,17,21,23,24,32 etc
what makes it a valid range is the comma between the numbers, no spacing and no full stop at the end
to further add confusion
when printing all of the pages just click all pages and it will print one sided all of the pages so no numbering is required
however if you want to save paper and reduce the size of the document
click pages 1,3,5,7,9,11,13 through to ,57
print those pages then turn them all around and upside down reinsert in the printer
now select pages 2,4,6,8 through to ,58 and print
that will give you printed data on each side of the paper in the correct page number order
to get to know how to reinsert the paper test with a print page 1 then reinsert and print page 2 to make sure that you have turned the paper the right way round
Samsung ML-2510... | Answered on Jun 28, 2017
This may be a help. I had a similar problem with an ML-2850 which fresh out of the box refused to print, not even a test page, green light followed by red and the smart panel showed that the printer thought that there was no toner in it.
After struggling with it for an hour I hit upon the following.
Turn off the printer.
Take out the toner cartridge.
In the hole where the toner came from there's a gear on the left hand side which is sort of diagonal mesh to match the underside of the toner cartridge. Rock it back and forth a bit and then stick the cartridge back in.
My guess is, if you're unlucky when you install a new cartridge you could have a situation where the gear is in exactly the wrong position, tooth to tooth with the underside of the toner so this gear doesn't mesh properly, the cartridge doesn't seat properly, which then shows the printer as having no toner in it. Waggling the gear just changes the position slightly and then voila. A bit like rocking a car back and forth in gear to free a stuck starter motor.
Samsung ML-2510... | Answered on Oct 04, 2016
Dear
You can use EPM(easy printer Manager) or smart panel. These files can down loaded from the samsung site. install and run in the PC it will show the status of the printer.
The red light blinks and printing is possible means get ready to replace the toner cart. with a new one.
Thanks. Printer Support SAMSUNG India
Samsung ML-2510... | Answered on Mar 04, 2015
Samsung ML-2510 Laser Printer Logo
349 questions posted
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
ML Samsung
  • ML Samsung
Most Popular Question
samsung ml 2510 printer picks up
  • Office Equipment & Supplies
