20 Most Recent Samsung S1030 Digital Camera Questions & Answers
You can very often recover deleted pictures from a camera memory card or USB Memory stick. However, to increase the chances of being able to recover pictures after they have been deleted you must not save any new photos, files or data to it.
When you delete pictures (or any files) from a memory card or USB memory device the data itself isn't deleted, just the file system pointers that says where the data for those files is located. The area where the deleted picture data was stored is also now marked as free space so it is available to the system for any new files to be written there instead.
If and when that happens, then it is too late to recover your deleted pictures so it is very, very important that new pictures or files aren't saved to the memory card in the meantime.
One of the easiest ways to see if your deleted pictures can be recovered is to try some photo recovery software. Recommended asoftech photo recovery as I used it before. download from link below
Camera photo recovery software
You may refer to this video tutorial
Samsung S1030... | Answered on May 15, 2019
funny thing with batteries is that they can get a memory = sounds stupid yes = if a battery is recharged when it has half charge and then fully charged it remembers the point , one it gains memory it wont charge past the last point = or the battery life is over = or the charger is faulty.
Samsung S1030... | Answered on Aug 16, 2014
In order to have more room on your card and more mermory for pictures and for this message to not pop up. You need to set your picture quality to low resolution and that should give you more room. If you have the ability to do video on the camera that takes up a lot of the memory as well.
Samsung S1030... | Answered on Apr 16, 2014
An 8gb memory card to too large for your camera. It can't handle the large space on an 8gb memory card. If I'm not mistaken the s1030 can only go up to a 2gb memory card.
Samsung S1030... | Answered on Jan 15, 2013
The S1030 works with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
Samsung S1030... | Answered on Sep 08, 2012
Clear it by putting in a compatible memory card. The S1030 works with SD cards. Your 8GB SDHC card in not compatible. You need to use SD cards, 2GB and smaller.
The S1030 works with SD and MMC cards,not with SDHC cards. You need to use SD cards 2GB and smaller.
Samsung S1030... | Answered on Aug 29, 2012
I did this aswell, All you can do is tape it unless you can find a new spare part!
Samsung S1030... | Answered on Dec 13, 2011
If the white line occurs on all pictures taken, then it means that the digital sensor is broken. You can take the camera to a repair center, but it would probably be cheaper to puchase a new one.
Before making this conclusion - try changing the battery(s) out and also, go into the camera menu and reset the defaults. Lastly, ensure that there is no obstruction in the way of the lens when you take the picture - sometimes I accidentally have my camera strap or thumb/finger in the way. (I know these sound simple - but it wouldn't be the first time it has happened to someone!)
I hope this information is helpful!
Samsung S1030... | Answered on Dec 01, 2011
Hi Allen,
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please pleasefirst contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Regards,
Suhail
Samsung S1030... | Answered on Oct 27, 2011
Go to this website and try the solutions.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Samsung S1030... | Answered on Oct 19, 2011
I think you might have to take the entire cam apart into 2 pieces. try that. Just make sure you use the right screwdrivers or it might become impossible to take apart.
Samsung S1030... | Answered on Aug 17, 2011
Visit the link below:
Samsung S1030 disassembly .
You can also try to reset the camera...
>Reseting Camera
1.Turn on the Camera
2.Press and hold the Up button and Shutter button and then press the Power off.
3.Turn on the camera and check whether the camera is reset or not.
Samsung S1030... | Answered on Aug 04, 2011
Samsung S1030... | Answered on Jul 17, 2011
Yes. The S1030 can use SD cards and SDHC cards.
Samsung S1030... | Answered on Jun 24, 2011
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance. This is only a suggestion, it works 90% of the time, so please do not down rate me if this does not work for you.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Samsung S1030... | Answered on Feb 20, 2011
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
Samsung S1030... | Answered on Feb 08, 2011
Samsung S1030 Digital Camera Logo
56 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cameras
  • Samsung Cameras
Most Popular Question
battery charger issue
  • Cameras
