20 Most Recent HP Pavilion dv9000z Notebook Questions & Answers
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
HP Pavilion... | Answered on Jun 27, 2019
Outlook and Outlook Express both report that error number when they can't find or connect to your mail server.
Understanding what's happening is fairly easy. Fixing requires some additional information.
I'll focus here on Outlook Express, but similar steps are appropriate for Outlook as well.
Typically you'll see an error message much like this:
oemailservererror.png Unfortunately, many people seem to fixate on the error number at the end - 0x800ccc0d. While that can be useful, and it's easy to search on, they're missing all the additional information that Outlook is providing in the error. Specifically, this:
The host 'wrongmailserver.com' could not be found.
That's a big clue as to what's going on. Your email account is configured to retrieve email from the server 'wrongmailserver.com' (a fictitious server I made up for this example), and Outlook Express cannot connect to that mail server.
Step one? Make sure you can connect to anything else on the internet - any web page will do. Error 0x800ccc0d can occur because you're not connected to the internet at all, and visiting any random web page simply verifies that your internet connection is working.
If your internet connection is not working, that has nothing to do with Outlook, Outlook Express or error 0x800ccc0d. Your mail failure is just one symptom of not being connected to the internet.
If you are connected, step 2 is to validate your Outlook Express account configuration. Specifically, if you click on the Tools menu in Outlook Express, then click on the Accounts menu item, and then in the resulting dialog box click on the Mail tab, you should see something like this:
oeaccountsdialog.png "If the Incoming Mail (POP3): setting is wrong, then error 0x800ccc0d can result." If you have more than one account, you may see multiple items in the list. Click on the one with which you are having trouble and click on Properties. In the resulting dialog box, click on the Servers tab and you should see something like this:
oeaccountproperties.png Note the arrows pointing at the two instances of the mail servers you would be using: one for POP3 (incoming email) and one for SMTP (outgoing email).
If the Incoming Mail (POP3): setting is wrong, then error 0x800ccc0d can result. In fact, the error message you got originally, "The host 'wrongmailserver.com' could not be found." is telling you that the mail server specified here could not be contacted.
So, what do you do?
I can't tell you what this setting should be, because it varies from ISP to ISP. What I use is different from what you use. So, you'll need to double check the information you were given from your ISP to see what they said your mail server name should be. Make sure you've entered that exactly. In fact, it probably makes sense to double check your entire configuration while you're here.
It's also possible that your mail server may simply be down - the ISP could be having trouble, for example, or the ISP could have changed mail servers. You'll need to contact your ISP to determine if this is the case, and whether or not they have an alternative mail server you can use, or how long you might need to wait for things to be fixed.
HP Pavilion... | Answered on Apr 08, 2019
I had the exact same problem so I called HP support.The instructions were- remove power cord from lap top if power cord is connected, then remove battery, connect power cord to lap top then turn on lap top by holding power button down for 30 seconds. It booted up, no problem. The proceedure is to remove static electricity.
HP Pavilion... | Answered on Jan 16, 2019
you must have a bluray supported software such as power dvd 9 or win dvd you must purchase software to playback bluray disks as the codec is licenced
HP Pavilion... | Answered on Nov 21, 2018
New computers rarely have modems built in, you can tell by the existence of a RJ-11 (2 conductor) jack on the side or back to plug your phone line in. And also right click computer then properties then device manager. Then look for a modem under Network...
If you have a serial port, an older external modem might do the trick, But likely you have only USB ports and are chasing more trouble to go from USB to Serial to Modem.
A USB modem is probably expensive as well.
For the mouse, look at a second hand store for a USB mouse or borrow one and try that.
HP Pavilion... | Answered on Feb 27, 2018
Make sure you have the mouse driver installed, the mouse driver for the trackpad, allows more functions and features from the trackpad. Like the one you want.
See the hp website, look under keyboard,mouse,input section.
HP Pavilion... | Answered on Feb 18, 2018
As per the error message you had received, I beleive that the File System (Partition Table) in your Hard Drive is curropted because of which you are unable to store any data.
The only option available is to burn the requried data into DVDs and perform full recovery and reinstall the Operating System to factory default settings.
This will format the Hard Drive and will also recreate the File System (Partition Table).
HP Pavilion... | Answered on Dec 21, 2017
anybody think to change the monitor (screen) back ground color
HP Pavilion... | Answered on Nov 05, 2017
vast posts here on black screens of deathh
the screen is 100% black and never once shows text or that HP logo. 100% dead black, then that is the screen back lamps dead
as most long ago did, go dead , just not yours.
called the CCFL lamps dead.
ok the battery out test1
the other check is the fan is the fan blowing, it must or the CPU overheats fast and (it shuts itself off, like magic (intel inside)
see slide show here for Laptop link packup causes.overheated
http://www.pcdied.com/overheated.html
my guess is it is there, below... as all do every one at 20k hours.
see flash light test. there. on test one, do that.?
see test #1 (battery out, ac pack connected and working)
http://pcdied.com/black-screen.html#Basic-basics-101
if the flash sight trick passes, (see data) ask how to fix that
or read the service manual at HP.
see the list of HP , with CCFL here. dv9000 is it.
http://pcdied.com/monitors.html
if yes, ccfl dead
see here
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xdv-9000+ccfl.TRS0&_nkw=dv-9000+ccfl&_sacat=0
1% fail this way for inverter bad, 1 in 100.
see same page above for inverters sold the lamps run of it and it makes 500 to 1000vdc to do that,, HV inverter.
HP Pavilion... | Answered on Oct 30, 2017
bad keyboard, buy a new one.
bad HP driver for it. missing,/bad/wrong or corrupted
is this XP, what OS is there?
why post lacking OS name, windows what?
those are the simple causes.
if you take a boot disk/ or mem stick with linux live on it
and it fails,. the keyboard is bad.
if not the OS is corrupted, a 5 min test, and bingo... why/
u better remove ur ram and reinsert in slot if you have two rams in mother board please take out one ram from one slot and check if it same take out another ram from slot and check it
HP Pavilion... | Answered on Oct 12, 2017
well; first is to find out what that is, its machine code .exe
and as such can be virus.
you posted not tellowin what OS you are running.
windows 10?
its HP live TV
so reload it, that means go to HP and get the live TV app
and install it, if you want it.
if you have no need for it, use the windows unstaller.
called (in w10)
i never use windows for uninstalls ever.
I use revo uninstaller, (pro)
it pulls them out with by the roots, and dirt balls and all.
like all things 1/2 installed and DLL-H3LL
we remove if first.
click on control panel
click program and features, see the HP apps there.
remove the TV one.
bingo fixed.
HP MediaSmart Live TV or HP MediaSmart TV
if you need it ask at HP ,we are NOT HP,we be only lowly fixya.
HP Pavilion... | Answered on Oct 09, 2017
sure the screen is bad.
internal.
the DV2000 runs CCFL back lamps,
all go dim with age, and yellow. all do.
so can be only this.
bad CCFL lamps or the CCFL inverter driving it.
vast PCs like this are in the recycle centers. now.
endless.....
goodwill has them in piles..
http://pcdied.com/cheaper.html
HP Pavilion... | Answered on Jul 26, 2017
Contact HP for Care at ((+ 1-800-585-2494 ))
Toll Free Number
HP Pavilion... | Answered on May 09, 2017
How you confirm that yoy have problem with screen and not with gpu (graphics card) of the laptop. If you connect the notebook with external monitor you get picture or still white colour.
HP Pavilion... | Answered on Apr 16, 2017
If you still have the recovery partition:
Restart your computer then look for the F key which controls your BIOS then look for the option "reload default setting" then follow the on-screen instructions.
If not, please let me know what version of windows you have installed, the type of recovery media?
HP Pavilion... | Answered on Apr 13, 2017
The issue might be due hardware malfunction or lack of system performance or corrupt os.
perform hard drive self test:
Hard Drive Self Test:
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test pass then perform below steps:
Improve system performance:
Follow the steps provided in the below url:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00815926
if persists, restore the ntoebook to factory settings.following below steps in the url
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703:
HP Pavilion... | Answered on Dec 24, 2016
Hi Walter, The link below is a YouTube video showing how to fix your lap top shutting down by it self, Also there's videos down the right side of the link that may help as well, By the way instead of using a straw I'd undo the back..........CHEERS..
Don panic Is your laptop shutting off by itself or slowing down during use
HP Pavilion... | Answered on Oct 24, 2016
HP Pavilion dv9000z Notebook Logo
2,207 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
file system error 1073741521
  • Computers & Internet
