20 Most Recent HP LaserJet P3005 Printer Questions & Answers
Please check the cartridges it see if the toner is finish,clean the print head because it may be block up or you can replace it if it is damage.
HP LaserJet... | Answered on Mar 19, 2019
That sounds like to me that the pick up rollers are not pulling the paper. Replace the rollers.
HP LaserJet... | Answered on Oct 02, 2017
Toner Cartridge Drive need to be change
HP LaserJet... | Answered on May 30, 2016
To remove paper jam. Just remove the toner cartridge and pullout jammed paper. If still coming paper jammed error message. Switch of the printer and the printer will roll over the paper jammed.
Changing of fuser drum is required if the print out came with the black strips. This happens when you print large volume of printing jobs.
HP LaserJet... | Answered on Mar 25, 2016
Most times a 49.xxxx error on an HP printer is caused by either the print driver, firmware or the print job itself.
If it happens when printing a PDF file try sending the file to the printer as an image.
Upgrade the print driver and the firmware.
You may need to disconnect the printer from the pc or network, power it off and pull the plug for a couple of minutes to clear the error.
If it's a network printer it would be a good idea to check the printer queue for any jobs still in it and delete them before powering the printer up again.
HP LaserJet... | Answered on Nov 02, 2015
check cables connectivity otherwise replace the fuser
HP LaserJet... | Answered on May 25, 2015
This could be a setting on the printer, in the driver on your computer, or the document you are printing.
First, try printing a different document and see if the problem persists.
Reset the printer to factory default settings, also referred to as a cold reset. HP has instructions on their website here: HP LaserJet 2300 Printer Series Resetting the Printer Cold Reset
You can also go into the printer driver on your computer and reset settings there, or uninstall and reinstall the printer.
HP LaserJet... | Answered on Mar 08, 2015
Power off and then hold down check mark button as you power up. This resets the paper settings.
HP LaserJet... | Answered on Jan 31, 2015
Plastic flags in the output bin can get stuck
Must be an aftermarket or refilled toner cartridge. These toner cartridges have a chip on them that must be changed when refilling or remanufacturing the cartridge. It looks like you got a cartridge where the chip has not been changed. I would return it for another cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
HP LaserJet... | Answered on Nov 26, 2014
Just lift up the Toner Access Door, take out the toner and replace with a new toner cartridge.
Your problem description is not clear, but based on experience I bet that your printer is taking three sheets of paper at a time. The pickup roller in tray 2 and the separation pad in the tray are probably worn out. They are easy enough to replace. You can verify that printer works properly by printing from manual feed tray and if that works ok then above solution is likely your fix.
chek for papers under toner area and check sensors
HP LaserJet... | Answered on Nov 22, 2014
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
HP LaserJet... | Answered on Mar 12, 2014
HP LaserJet P3005 Printer Logo
274 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp 3005dn prints black horizontal lines
  • Office Equipment & Supplies
