20 Most Recent Panasonic Lumix DMC-TZ3 Digital Camera Questions & Answers
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Panasonic Lumix... | Answered on Oct 23, 2018
what is the reflction of the camera. is your camera full charged or some button is in a normal condition.
http://www.skiliwah.cn/
http://www.digitalcamera-parts.net/
e-mail:e-8090team@hotmail.com
Panasonic Lumix... | Answered on Sep 26, 2018
Lens covers are delicate things. A bit of dust or dirt inside and the the springs can't do their job. When cleaning doesn't work, to repair this I remove the lens cover and shorten the springs by cutting off a bit and then reattaching them. A small bit of mollyd to lubricate helps too. never use oil or silicone.
Panasonic Lumix... | Answered on Jan 09, 2018
Probably, as this is obsolete, time to replace it with the newer
Panasonic DMCTZ5 Digital Camera
Panasonic DMCTZ5 Digital Camera Black 9 1MP 10x Optical Zoom 3 0 LCD
Other sales sites are available.
Panasonic Lumix... | Answered on Jun 09, 2017
The camera is probably damaged, this also happend to my DMC-TZ5 as well after a few (5-6) years of heavy use but without any visible damage, a repair is most likely more expensive than just buying one of the new lumix cameras which have also improved A LOT, so you wont be disappointed!
Panasonic Lumix... | Answered on Apr 13, 2017
Do the pictures still look this way when they are downloaded to your computer or just when played back on the camera screen? Was the camera exposed to high heat (like being left in a hot car)?
Panasonic Lumix... | Answered on Apr 12, 2017
Check out "LIBERTY" synthetic oil... on AMAZON
Watch the shipping and FREE TRIALS...
If you need MAGNIFIERS (jewelers loupes)... forcepts, duster cans... etc
NOW would be the time... to qualify for FREE
shipping
Usually for clocks... it is quite excellent.
Use it very sparingly ...
Clean with isopropyl alcohol...
Use a DUSTER can or EMPTY air brush
to blow out
And apply with a tooth-pick
Remember ... sparingly
(stuff works wonders)
Amazon com Liberty Oil the Best 100 Synthetic Oil for Lubricating Your...
Panasonic Lumix... | Answered on Apr 08, 2017
Hi
the LCD screen may be faulty, or the connecting strip loose or corrosion on it, clean, if necessary change.
Panasonic Lumix... | Answered on Apr 20, 2016
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Panasonic Lumix... | Answered on Aug 16, 2015
Panasonic Lumix DMC-TZ3 Digital Camera Logo
776 questions posted
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
black screen except all camera functions
  • Cameras
