20 Most Recent Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Questions & Answers
You will need a code in order for the tv functions of you sky remote e.g volume to work.
Click here to find out what remote control version you have.
If you have a remote control was produced after 2002 or there is no sticker
click here to use Sky's code look up tool.
Most SKY+HD Remotes are produced after 2002
Sony BRAVIA... | Answered on Mar 24, 2019
Most language options on electronics are found under "Settings"
Switch on
Menu
Settings
Preference
Language
Sony BRAVIA... | Answered on Apr 18, 2018
Remove the LVDS cable, the one going to the input of the tcon board and see if it goes dark, if it does the Tcon board has failed
Sony BRAVIA... | Answered on Jan 31, 2018
Without a remote control, you can't select its inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sony BRAVIA... | Answered on Aug 20, 2017
We can not undo what you have done 7 years ago SORRY
Sony BRAVIA... | Answered on Jun 09, 2017
The main board controls the volume. You can get a new one here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sony BRAVIA... | Answered on Nov 04, 2016
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ . Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Sony BRAVIA... | Answered on Nov 01, 2016
Check the Volume on the TV, the audio jack is tied to the TV volume control.
Sony BRAVIA... | Answered on Oct 11, 2016
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Sony BRAVIA... | Answered on Aug 24, 2016
there is a T con error please replace the T con in this condition
Sony BRAVIA... | Answered on May 08, 2016
someone press the mute button by mistake
Sony BRAVIA... | Answered on Apr 09, 2016
Hi, yes you can connect two hdmi they should come up as hdmi 1 and hdmi 2 on your tv hand controller.
Sony BRAVIA... | Answered on Dec 27, 2015
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Sony BRAVIA... | Answered on Dec 03, 2015
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sony BRAVIA... | Answered on Sep 03, 2015
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
540 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
change language kdl 40v2500 please help
  • Televison & Video
