20 Most Recent Brother MFC 240C All-In-One InkJet Printer Questions & Answers
I am a Brother employee working for the software technical support department.
The specifications for this machine are listed on our website at the following link:
http://www.brother-usa.com/MFC/ModelDetail/4/MFC240C/spec
The MFC-240C includes USB interface, but does not have a wireless network card.
Brother Software Technical Support
All in One Multi Function
Brother MFC 240C... | Answered 3 days ago
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Brother MFC 240C... | Answered on Sep 12, 2018
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Brother MFC 240C... | Answered on May 09, 2018
slide scan is not an option on that model. slide scanner is an option in some models of scanners. I have a HP one as most HP scanners have the setting built into the scan firmware that lowers and higher the light to get correct scan. brother model will not do this its just normal scan setting.
Brother MFC 240C... | Answered on Feb 17, 2018
It sounds like the actual ink sensor has failed. You can check if it has a print head cleaning routine in the software on the computer. Most likely the actual ink sensor has died though, I've seen this many times. Call Brother to confirm, or maybe if it's still under any kind of warranty: 877-276-8437
Brother MFC 240C... | Answered on Jan 11, 2018
You can attach the printer directly through USB cable to your computer and print, or you can connect the printer and your computer to the same wireless network and then print using the wireless and your connection.
Internet is not necessary, only a communication path needs to be established. For this whether its your neighbor's wifi network, your own wifi network, a usb cable connection between your pc and printer etc printing will be accomplished.
Brother MFC 240C... | Answered on Apr 26, 2017
You may visit at : How to Fix Brother Printer Is Not Working Problem Down reporter and find the solution for printer related problems.
Brother MFC 240C... | Answered on Mar 27, 2017
Brother MFC 240C All-In-One InkJet Printer Logo
937 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
brother printer mfc j615w showing
  • Office Equipment & Supplies
