20 Most Recent Maytag EPIC MFW9700S Front Load Washer Questions & Answers
Your drain is clogged, not the one in the wall where the drain hose goes, but the internal drain, you have to use a 7mm quarter inch drive socket and a 2 inch or longer extension. There are three screws at the very bottom of the washer which must be removed. When standing you cannot see these screws, you have to lay down and look under the washer, between the feet of the washer to find them. Once the bottom cover is removed there is a "cylindrical box" thing with a front cover, the front covers is simply screwed into the cylindrical box housing, unscrew it. Warning, there is a lot of water in here so don't be sitting when you remove it. When you get it open you will discover that this is the internal filter, you'll find small socks and coins and god knows what else in here. Now follow the drain line out and feel it from the outside by pinching it to see if it is clear, if it is clear it should compress quite easily if it is clogged remove it and **** it out with a wire hanger. Reassembly is the opposite of disassembly. This should fix you error message. And buy the way if you remove the top cover there is a "Technicians Manual" stored inside the washer under the top cover that describes some of this procedure and defines all of the error codes.
Maytag EPIC... | Answered on Jul 04, 2018
should resolve itself with repeated rinses
Maytag EPIC... | Answered on Jun 11, 2018
check that there is a small tube in the area as it is around that spot that the pressure hose goes up to the water level selector switch
otherwise use a short metal thread screw with a fibre washer under the head to plug the hole
you can get screws as short is 3/8 to 1/2 " and thick in diameter to fit into the hole
too long and it will bind up on the wash tub
Maytag EPIC... | Answered on Nov 21, 2017
May be a water pressure sensor problem.
This tells it when the tub is full.
start with this video
https://www.youtube.com/watch?v=2pIVkAxWSXg
Maytag EPIC... | Answered on Nov 03, 2017
Unplug or disconnect power to the machine and access the electronic control board. Remove the screws in the back of the top panel, then lift the back of the top panel and slide back to remove.
The electronic control board is located on the left side near the top. It's very common for that part to fail. Look on the back side for a burned or scorched mark near the relays.
Measure the resistance between P1-3 and P1-4. If the resistance is between 1-6 ohms, replace the control board. If not check the belt switch for continuity.
Check the motor windings at the motor switch. Disconnect the motor connector. Measure the run/main windings between the blue wire in back and the white/orange wire (2.4-3.6 Ohms). Measure the start windings between the blue wire in back and the Violette wire (2.4-3.8 Ohms).
Lift the idler pulley up and measure between the two blue wires to check the belt switch.
Ref. link: https://www.applianceblog.com/mainforums/threads/44767-Maytag-Epic-won-t-start
Maytag EPIC... | Answered on Oct 11, 2017
Put you bleach into the machine whist it is filling using the left part of the drawer.
Maytag EPIC... | Answered on Jul 03, 2017
the main board might be damaged due to the damp and cold. the boards don't like wet and damp places as it can damage the copper on the boards causing them to go green and be eaten away, you may be able to repair the board using bridges and repairing the damage.
Maytag EPIC... | Answered on Jun 05, 2017
what you are describing is not due to the leak. There are no fuses in the unit to protect the valves. The fuses protect the whole machine and if they failed, the unit wont power on at all. There is a control panel board on the front and a control board inside the unit near the back top. Check the connections sounds like when the tech cleans the valves that he is wiggling connections that fail later again.
Maytag EPIC... | Answered on Apr 26, 2017
This is a good webpage to look at: http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC9NTU9ZLU1Bag==/sno/0
Your error code indicates that the motor is having difficulty turning.
Is the machine brand new?
If so, it's possible that the shipping bolts haven't been removed.
Note: To remove the error display, press Pause/Off or Pause/Cancel twice.
More info here: http://maytag.custhelp.com/app/answers/detail/a_id/2890/sno/0
Maytag EPIC... | Answered on Apr 11, 2017
issue him with a written notice of the tear ( also take a photo) so that he cannot blame you for the problem
It is not your fault but normal wear and tear for a machine that old
It sounds like he is trying it on so that you have to fix it
unfortunately it is his machine and repairs are his responsibility regardless of how rough or careful you are
if push comes to shove talk with a lawyer
Maytag EPIC... | Answered on Mar 29, 2017
Maytag EPIC MFW9700S Front Load Washer Logo
937 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
disposable diapers
  • Washing Machines
