20 Most Recent Sansui DTV2760 27" TV Questions & Answers
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sansui DTV2760... | Answered on Oct 21, 2017
hi
how to open child lock for this sansui tv
Sansui DTV2760... | Answered on Nov 22, 2016
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma TVs are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
Sansui DTV2760... | Answered on Mar 02, 2015
This company has been around for many many years. https://www.samswebsite.com
Sansui DTV2760... | Answered on Feb 19, 2015
Sounds like picture in picture (pip) and the numbers are probably the channels for the pip.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Sansui DTV2760... | Answered on Feb 04, 2015
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sansui DTV2760... | Answered on Aug 05, 2014
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
Sansui DTV2760... | Answered on Jul 16, 2014
You should have its remote control to set the aspect ratio to picture. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier.
Universal remote controls are available at most of the electronic spare part selling shops or online by Ebay or Alibaba.com.
Sansui DTV2760... | Answered on May 19, 2014
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Sansui DTV2760... | Answered on May 15, 2014
Sounds like LOT fault. Contact any service technician.
Gopakumar Gopalan Google
Sansui DTV2760... | Answered on Mar 28, 2014
0278,o279,9277. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Sansui DTV2760... | Answered on Mar 05, 2014
Check all the solder terminals at the video output card to this set. Re-solder all the suspected solder terminals, by applying a little more solder to each solder terminals, without making any solder bridge short in between adjacent solder terminals. This card can be located at the back of the picture tube neck, will directly plugged on to it, and can be detached for repair. Check all the solder terminals to the CRT base socket too. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Sansui DTV2760... | Answered on Jan 09, 2014
Check all the other components related with this power transistor, particularly to the free-wheeling capacitor, connected to its collector to ground. Replace it with a new one of same capacitance value, before replacing the transistor again. Check whether there is a short circuit to horizontal winding section at the deflection coil. If LOT has any fault, BU won't last for long. Will get overheated within seconds after the set is switched ON. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Sansui DTV2760... | Answered on Dec 25, 2013
Hey check crt board for loose soldering ,check main board where the wires lead to the crt board ,check video/chroma circuit for loose soldering
Sansui DTV2760... | Answered on Dec 12, 2013
289 questions posted
Popular Products
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
unlock childlock sansui sv t21pa2s
  • Televison & Video
