20 Most Recent Sansui D 27" TV275 TV Questions & Answers
Is it possible that you typed the model # wrong? I can't find anything for that midel. If it has a hdmi port chances are it is 720p which would be hdtv. If not then it is most likely a standard 480p t.v.
Sansui D 27"... | Answered on Mar 02, 2015
Try these codes first. These are the common codes used to bypass the password. If you get succeed, after getting the TV to ON, reset it with an other password of yours' before switch it OFF. 6668.0000.6868,0101. For more information go to http://electronicshelponline.blogspot.com/
Sansui D 27"... | Answered on Dec 18, 2013
0039,0031,0033,0030. Try these codes. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Sansui D 27"... | Answered on Dec 08, 2013
It appears by your sentence structure you may be trying to undermine your own protection. How do I know you are not a child?
Sansui D 27"... | Answered on Nov 02, 2013
I am not sure if this solution will work, but I posted the manual for these TV's.
If you call their toll free number during a weekday they may be able to help you get it fixed.
Good luck,
Tom
Sansui D 27"... | Answered on Mar 16, 2013
Replace , front panel switches , one or more switches goes high resistance
when suppose to be open circuit , my sv2918 74cm was doing weird things
with these switches going bad
Sansui D 27"... | Answered on Dec 23, 2012
welcome to fixya
its mostly Sounds like you have lost video somewhere in the video circuits. Possibility is that the picture tube could have gone bad or lost filament voltage.
You can check to see if you have high voltage by holding your bare arm close to the screen. The hairs will stand up if you have high voltage. Absence of high voltage will also cause a black screen,but the sound might not work either since on some sets the power for the sound is supplied from the same circuit as the high voltage.
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent. If the picture does not return, then you have a more serious problem
do comment if it does or it doesn't help you ! we will try to help !
Sansui D 27"... | Answered on Nov 18, 2012
Reset the TV to its factory settings. Refer its user manual for details.
Sansui D 27"... | Answered on Aug 06, 2012
http://www.sansui.newremotecontrol.com/catalog_item.php?catnum=07640KL030 click here to visit the Sansui webite, this is the model you are looking for.
Sansui D 27"... | Answered on Apr 05, 2012
Hell My Sansui Hard rock 21 eye tv has been chennal & voliume locked.
or remot not working tv screen small
Sansui D 27"... | Answered on Mar 04, 2012
SPECIFY the line vertically or horizontal?
Sansui D 27"... | Answered on Sep 01, 2011
hi,
You have to press the channel up/down (program up/down) on your remote to access different channels.
ok
Sansui D 27"... | Answered on May 24, 2011
Hello
The memory IC of your TV has damaged. It can be located very near to the main system control IC, an eight terminal one, can be desolder out from the boar very easly. Its number is more important when replacing it. There is no tuning lock occurs with your TV; and the reason is damged memory IC. OK.
Sansui D 27"... | Answered on May 17, 2011
Hello
Select one [One For All URC - 3021, universal remote control. Sansui is lited in its codes. You will get its catelogue and user manual which contains all proceedings about how to setup with it your Sansui TV.
The code for Sansui is
[0463]
OK.
Sansui D 27"... | Answered on May 05, 2011
Ur computer video mode are setting to high.Go the computer Control Panel change down the resolution like 800 tv resolutions should work fine.
Sansui D 27"... | Answered on Feb 25, 2011
Sansui D 27" TV275 TV Logo
43 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
could please advise fix t v
  • Televison & Video
