20 Most Recent Mitsubishi WD-62531 Projection Television Questions & Answers
The biggest enemy of bulbs like that is heat. Make sure the fans are running and are clean. Make sure the fan stays on for a while when the unit is turned off. Other than that there is little you can do without adding a fan or other modifications.
Mitsubishi... | Answered on Oct 29, 2017
lamp has failed. Check your manual for removal instructions but you can find a new lamp with a good warranty here. Mitsubishi DLP TV Bulbs
Mitsubishi... | Answered on Oct 02, 2015
Hello, this set does not have a "blue lens". A Mitsubishi uses a different type of system than like the Sony dlp's that use a 3 lcd system. the Mitsubishi uses a video chip on the video processing board (the DM board) and a color wheel to produce the image and a lamp to light it up. The chip is most likely the issue a fairly costly repair. tks
Mitsubishi... | Answered on Jan 31, 2015
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Mitsubishi... | Answered on Aug 05, 2014
There is no air filter on a tv.
Mitsubishi... | Answered on Jul 26, 2014
you need a new bulb, they're about $100, order from Mitsubishi online.
Mitsubishi... | Answered on Jun 27, 2014
I have the same model that had the same problem, all I had to do was clean the blue lens in the optical engine. looks great now. free fix.
Mitsubishi... | Answered on Jan 09, 2013
Mitsubishi WD-62531 Projection Television Logo
85 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
mitsubishi wd 62531 yellow hue over half
  • Televison & Video
