20 Most Recent Sharp AR-5320 Black and White Copier Questions & Answers
Check fuser unit for rollers or exit sensor problems. Rectify the problem if its gear and replace. Then reset with code 14.
Sharp AR-5320... | Answered 2 days ago
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
Sharp AR-5320... | Answered on Jul 12, 2019
toner light needs to be reset.
(Then again you should throw out the old beast and get something new.)
Sharp AR-5320... | Answered on Jun 04, 2019
how to reset the toner chip as it is costaly
Sharp AR-5320... | Answered on Mar 15, 2019
Have you tried a trouble clear?
Sharp AR-5320... | Answered on Feb 08, 2019
L4 mean this copier main motor is not move or run.
First time, Open your copier back cover and check any gear is broken,solve it .Or clean all mechanical which one jam.If you are not a technician so you call a service Engineer who are qualified this Brand.
Sharp AR-5320... | Answered on Jan 25, 2019
need AR-5320E driver
Sharp AR-5320... | Answered on Dec 31, 2018
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step.
Thanks
Sharp AR-5320... | Answered on Dec 30, 2018
hi dear may you dont have put the origenal document proper or may be blank, just put writing side down on the glass or if u are using ADF put the writing side up side,
thanks
Sharp AR-5320... | Answered on Jul 03, 2018
Can not be done. people then would reset the counters on old machines and sell them as new
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp AR-5320... | Answered on Apr 24, 2018
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Sharp AR-5320... | Answered on Apr 23, 2018
Coppy light
Sharp AR-5320... | Answered on Dec 12, 2017
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Sharp AR-5320... | Answered on Dec 08, 2017
Could be a number of reasons. Try rebooting pc after powering off and on again the printer.
Sharp AR-5320... | Answered on Sep 28, 2017
it means that the thermistor in the fusing unit is open
which could indicate that it may have become faulty or is because of power fluctuations, a simple crop 14 reset should remove the error, but if it returns it should be looked at by a qualified sharp technichian
Sharp AR-5320... | Answered on Sep 14, 2017
Download adriver from support.sharp.net.au and re install your printer with pcl6 driver.
Sharp AR-5320... | Answered on Aug 30, 2017
Sharp AR-5320 Black and White Copier Logo
704 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
sharp xerox machine ar5516 bleaking man
  • Office Equipment & Supplies
